Author Topic: What did you do to your Jeep today?  (Read 38109 times)
Re: What did you do to your Jeep today?
« Reply #1225 on: February 11, 2018, 02:44:24 PM »
Paint on the floor, very sloppy
Offline joe98tj
« Reply #1226 on: February 11, 2018, 04:15:07 PM »
It'll fade
Mean, Green, Sticker Machine
Offline CitizenwithJeep
« Reply #1227 on: February 11, 2018, 05:41:18 PM »
It gives the garage floor character. You could put down a stencil with more paint and make it look like a design.
Offline joe98tj
« Reply #1228 on: February 14, 2018, 11:53:27 PM »
Late night making bump stops for the coil front coil buckets and patches for the rear of the frame. Gonna begin disassembly Friday night.
Offline Angrytj
  • Luciano
    • My YouTube channel
« Reply #1229 on: February 15, 2018, 02:11:13 PM »
making?
I have front bump stops you can have
2005 Jeep Wrangler Rubicon
Offline joe98tj
« Reply #1230 on: February 15, 2018, 02:14:36 PM »
making?
Not the actual bump stops, the pipe that holds it and the spring in place
Offline Angrytj
  • Luciano
« Reply #1231 on: February 15, 2018, 02:17:37 PM »
Well Ill just be chopping mine off if you want them
Offline joe98tj
« Reply #1232 on: February 15, 2018, 02:20:54 PM »
If you plan on doing that by Saturday sure
Offline Paul'TheGuest'W
« Reply #1233 on: February 15, 2018, 06:42:43 PM »
I changed my oil.
Offline Angrytj
  • Luciano
« Reply #1234 on: February 15, 2018, 07:55:26 PM »
that wont happen, sorry
« Reply #1235 on: February 15, 2018, 10:10:41 PM »
Almost took it for a drive for grocery's tonight - but the tank was almost empty and the company vehicle was full of free fuel...
Offline Prof_Oaks
« Reply #1236 on: February 15, 2018, 11:05:40 PM »
Pulled the rear axle out in prep for gears, disk breaks and frame stuffiness. Gonna be a busy weekend
« Reply #1237 on: February 16, 2018, 07:41:34 AM »
good luck!
Offline Prof_Oaks
« Reply #1238 on: February 16, 2018, 07:49:36 AM »
Breaks and stuffiness.  Remember kids, always proofread your posts or you’ll end up like me...
Offline joe98tj
« Reply #1239 on: February 16, 2018, 07:53:55 AM »
Auto correct got ya twice there
Offline joe98tj
« Reply #1240 on: February 17, 2018, 01:40:01 PM »
Just fiddling with some minor stuff today
« Reply #1241 on: February 17, 2018, 03:01:35 PM »
I put used, moderatly chopped mud tires on it because my radio was to loud.
Offline Prof_Oaks
« Reply #1242 on: February 17, 2018, 07:02:53 PM »
One down one to go.  Jeep is 5/6 stiffened
Offline joe98tj
« Reply #1243 on: February 17, 2018, 07:51:55 PM »
Damn thats stiff
Offline Horn
« Reply #1244 on: February 20, 2018, 07:49:24 PM »
Checked CB tune. It's still in tune. I have a SWR meter if anyone ever needs to use it.
Practiced my amateur soldering skills to replace a bad light socket in my right fender flare. Socket was backordered so long I forgot for a while I had ordered it. Now all lights work again.
Thinking of starting to change some over to LED, starting with dim reverse lights.
Offline joe98tj
« Reply #1245 on: February 20, 2018, 08:32:52 PM »
Pqinted skid plates, greased some johnny joints, and took some parts off the engine so I can clean it so it can get covered in oil again. Also turns out the belt has been holding the alternator in place for sometime now since the lower bracket broke.
« Reply #1246 on: February 20, 2018, 08:42:43 PM »
Fixed Emily's intermittent brake lights. Brake light switch works better plugged in all the way.
« Reply #1247 on: February 20, 2018, 08:58:55 PM »
You didn't know the alternator seconds as a tensioner hahaha
« Reply #1248 on: February 20, 2018, 08:59:19 PM »
Funny how that works lol
Offline joe98tj
« Reply #1249 on: February 20, 2018, 09:03:08 PM »
I guess so
