Author Topic: What did you do to your Jeep today?  (Read 23594 times)
Re: What did you do to your Jeep today?
« Reply #525 on: June 19, 2017, 08:11:09 AM »
First of all, your angles are probably VERY off.  Center your axle with the lowers and then fix your caster with the upper control arms.  Once this is done if you still have clearance issues with the drag link, place the drag link in a press and push out the angle a little more basically moving the TRE away from the link.  This will also help with the Tie Rod to Diff clearance you get with some of the more bulky covers.
Offline Paul'TheGuest'W
« Reply #526 on: June 20, 2017, 08:24:17 PM »
I got rock slides for the curb at the mall.
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
« Reply #527 on: June 21, 2017, 07:55:09 AM »
 Changed the spark plugs.  (Still misfiring on Cyl 5)   :rolleyes:
 Took the doors off
Profile for Team_Oscar
Quote from: Theo Maassen
« Reply #528 on: June 21, 2017, 08:05:04 AM »
coil packs ?
  • Honorary Members
« Reply #529 on: June 21, 2017, 08:06:50 AM »
coil packs ?
 Must be...   Anyone have a coil bar for a TJ I can borrow to try?
« Reply #530 on: June 21, 2017, 09:32:24 AM »
coil packs ?
I have an extra one off a 2000 XJ you could try. Pretty sure they were the same. I'd like to hold on to it as a spare but your welcome to use it to diagnose the issue.
  • Honorary Members
« Reply #531 on: June 21, 2017, 02:39:40 PM »
coil packs ?
 I may take you up on that, and scoot over to Tom's to hook up the coil pack and his OBD scanner to test it.
 (the one I picked up doesn't show Misfires in real time like Tom's does)
« Reply #532 on: June 22, 2017, 07:48:06 AM »
Sounds good. Just let me know.
« Reply #533 on: June 22, 2017, 07:53:07 AM »
While you had the plugs out you should have checked the compression
  • Honorary Members
« Reply #534 on: June 22, 2017, 08:50:11 AM »
I don't have a tester.  We'll have to schedule some diagnostic time at your place.  :smile:
« Reply #535 on: June 22, 2017, 09:11:07 AM »
okey doke
« Reply #536 on: June 22, 2017, 11:46:54 AM »
coil packs ?
I have a couple.  Come grab one.
« Reply #537 on: June 23, 2017, 09:42:32 AM »
Not directly to the Jeep, but I used Jeep parts to do it! Horse shoe pits using d35 axle shafts as the stakes. We will be Doug backboards at a later date.
« Reply #538 on: June 23, 2017, 09:57:17 AM »
FRIGGAN AWESOME !
I poked mine with a stick
Offline Johnny Cupcakes
« Reply #539 on: June 23, 2017, 10:11:30 AM »
That's one good use of those shitty axles
Offline NickMaida
  • Probie
« Reply #540 on: June 23, 2017, 10:12:22 AM »
C clip horseshoes?  :razz:
'97 TJ 4.0 - 35s
« Reply #541 on: June 23, 2017, 10:14:01 AM »
That's Brilliant Jeremy!
"Teamwork makes the Dream Work!"
Offline Prof_Oaks
  • Probie
« Reply #542 on: June 23, 2017, 11:42:59 AM »
This is great
« Reply #543 on: June 23, 2017, 05:59:07 PM »
That's awesome!
« Reply #544 on: June 26, 2017, 01:12:44 PM »
Drove it to the property and discovered both rear calipers are frozen! :swear_mad: :swear_mad:
I used to avoid this by using my compressor to blow out all of the dirt around them after a muddy trail ride. :swear_mad: :swear_mad: :swear_mad: :swear_mad: :swear_mad:
Can't wait to get my shop and my compressor setup! :swear_mad: :swear_mad: :swear_mad:
end rant......
« Reply #545 on: June 26, 2017, 02:17:26 PM »
Moved it to the side of the house.
« Reply #546 on: June 26, 2017, 03:43:35 PM »
Nice XJ graveyard! :rotflmao:
« Reply #547 on: June 26, 2017, 06:18:01 PM »
With RedJeepster's assistance, confirmed the track bar mount isn't ovaled out (may have been in the past since there was already a washer welded there!), found a little play in inthe steering box output shaft.  Put the top back up (Really quick and easy on a TJ!)
  • Honorary Members
« Reply #548 on: June 27, 2017, 07:10:02 AM »
 Moved mine to the dead zone in my yard...  Clutch went the other day.
  Tarp isn't out YET though...
Offline ycatS75
« Reply #549 on: June 27, 2017, 10:19:14 AM »
Walked by it. Still wobbles so no go on driving it on the pavement.
'06 TJ built by SteveB
'15 JK Rubicon Hard Rock
