Author Topic: What did you do to your Jeep today?  (Read 38161 times)
Offline YJScrounge
Re: What did you do to your Jeep today?
« Reply #750 on: August 12, 2017, 07:41:00 PM »
Nice!
"This situation requires an immature act be carried out on someone's behalf - We're just the guys to do it!" - Animal House
93YJ: Waggy 44 HD's F&R, Rear Detroit Locker, Front Eaton Elec Selectable, 5:13 Motive, Anti-Wrap Bar, WARN Hubs, 6" Lift on 35" Mud Terrains, 4.0 HO w/K&N Air Tube, Live Wire Ignition, WARN 8,000 lb Winch, AtoZ Cage and Sliders, FX Tuner Seats w/Harnesses, OBA, SOA
01 RAM Cummins Tow Rig
01 WJ: Son's DD/Mall Crawler, 2" Budget Boost, Skyjacker Shocks, JK 17" Wheels back-up Tow Rig
Offline foldsct
  • Mall Crawler
« Reply #751 on: August 12, 2017, 09:12:24 PM »
Nice!
Thank you!! I like them much more than stock!!
Sent from my XT1635-01 using Tapatalk
« Reply #752 on: August 12, 2017, 10:03:31 PM »
Bye bye stock running boards.....
Perfect upgrade!  I wish mine were like that so as a short stature individual I didn't need a step stool just to reach the rock rail :-)
Offline foldsct
  • Mall Crawler
« Reply #753 on: August 13, 2017, 06:07:54 AM »
And that's why we got these........I HAVE to have the step!!  I can't get into the Jeep otherwise......... :rotflmao: :rotflmao:
Offline A new level
« Reply #754 on: August 13, 2017, 12:01:15 PM »
Looks good!
'16 JKR, Rock Krawler 3.5" Long Arm Off-Road Pro, 35" Nitto Trail Graplers
 Build thread http://forum.northeastjeep.org/index.php?topic=38405.new#new
Offline Paul'TheGuest'W
  • uh-oh he posted another avatar.
« Reply #755 on: August 13, 2017, 12:48:35 PM »
I put on mirror brackets as to not get a ticket.
OMG, this guys avatar may get me in trouble at work.  Not the personal use of company property, I'm safe there.  Its his avatar that's going to get me in trouble.  Phew its gone, now I can get back to screwing off on company time!!
Offline pote04
« Reply #756 on: August 13, 2017, 05:58:14 PM »
Took the skid plates off to straighten them out. took the crushed stock muffler and exhaust of. Put new Flowmaster thunder exhaust on. Put the skid plates back on and washed it!
t
Offline joe98tj
« Reply #757 on: August 13, 2017, 07:37:23 PM »
I got the pleasure of putting in a new radiator due to damage from my friend driving the jeep forward off the trailer when we were packing up to leave Rausch Creek last weekend.... suffered a nasty blow to the face too from the pipe on the hilift jack when I was lowering it down from getting the jeep back on the trailer.... Also started plans for picking up a new frame and preparing for a swap next spring and upgrading the front to long arms. Big plans for next year
Mean, Green, Sticker Machine
98 wrangler • 4 cylinder • in progress •
2014 Ram Power Wagon Tow Rig/World Class Gas Guzzler
Offline The Navy Commander
  • Shaq City is the place to rock. Semper Fi diddy
« Reply #758 on: August 14, 2017, 06:11:33 PM »
Dropped transfer case and rear drive shaft gonna need work on both.
In near future (next week) will need to rebuild rear LCA's and install all new rear brakes....  :rant:
Superwinch EPi 9.0 Detours Custom Bumpers/Dropkicks, 3.5" RE Superflex Lift, 1" Daystar Body Lift, 15" Cragar Street Lock D, 33" Dick Cepek Crushers,
Solid Axle Diff Covers, Jeep Medic Belly Up Transmission/Engine Skid Plate Combo, Other Kirby+Skid Row stuff
Blessed are those who, in the face of death, concern themselves only with the front sight post...
« Reply #759 on: August 15, 2017, 07:52:34 PM »
I put more gas in mine.  I really need to find out where it's going.
Offline Mr. Easy
  • Administrator
    • 72 scamp
« Reply #760 on: August 16, 2017, 06:43:28 AM »
I changed both wheel cylinders and tried to set the tow-in. Found that I bent another correct link tie-rod.
"it's like you're playing the triangle"
Offline MassJK
« Reply #761 on: August 16, 2017, 07:39:01 AM »
Drive by Braille gets expensive
Offline RedJeepster1
« Reply #762 on: August 16, 2017, 08:24:34 AM »
I have a couple stock tie rods lying around that can at least be adjusted if you want one to get you by for a while.
88 YJ, D30, D35, 4.10's, 4.6L Stroker, MPFI, Skyjacker 2.5" Lift, 33's
00 XJ, HP30, Front Truss, WJ Knuckles, High Steer, 3 link, Locked C8.25 w/ Chromo's, IRO Leafs, 4.56's, Rebuilt 4.0, JK Rubi Wheels, 35's
Offline Necroscope
  • What will be, will be...what will be, has been...
« Reply #763 on: August 16, 2017, 09:07:36 AM »
Had to take the Jeep to the dealer today. E-brake handle assembly was bad. Had to pull all the way up for it to hold. Seemed like it was skipping a couple of notches before it would catch. It's under warranty so no big deal. They even gave me a 2017 RAM 1500 5.7 HEMI for a loaner. Thinking I might have to sell my Dakota and move up a level...
Sent from my SM-G900P using Tapatalk
In the end, we're all just chalk lines on the concrete. Drawn, only to be washed away...For the time that I've been given...I am what I am...
Offline Mr. Easy
  • Administrator
    • 72 scamp
« Reply #764 on: August 16, 2017, 09:15:02 AM »
thanks for the offer. I was able to adjust it well enough by pulling the other tie rod end from the knuckle.
Online XJRV-Maki
  • salt no carry
« Reply #765 on: August 16, 2017, 10:32:13 AM »
Cut the stupid rockers off & trimmed the front fenders even with the doors to fit some 2x6 box. Also cut and folded the rear quarters. And I pulled off the faded door trim, should have done that a decade ago, looks so much better.
“If you don't do it this year, you will be one year older when you do.” - Warren Miller
Offline A new level
« Reply #766 on: August 16, 2017, 11:04:22 AM »
Bummer! That's why I love my RK tie rod. Damn thing takes a beating!
Online XJRV-Maki
  • salt no carry
« Reply #767 on: August 16, 2017, 11:36:46 AM »
It was always a challenge to get the tie-rod "bow" facing upwards for clearance and still maintain about 1/8ths toe in...if i were looking for steering I'd go aluminum, like this 1 ton set-up from SFR:
Online Right Wing Curmudgeon!!!
  • NE Jeep South Carolina Chapter
« Reply #768 on: August 16, 2017, 01:03:15 PM »
Someone used to make an Alumiflex tie rod for the Currie system..  Damned if I can find one! :swear_mad:
03 Rubicon, 4 inch Clayton Short Arm Lift, Rokmen TT and Gas Tank Skids, TW DS front and Rear, 1 inch Daystar BL, 35x12.5-15 Cooper STTs, Warn 9.5ti winch.
A good plan violently executed now is better than a perfect plan next week.(George Patton)
Life is tough! It's even tougher when you're stupid.
(John Wayne)
« Reply #769 on: August 16, 2017, 01:15:54 PM »
Seems like it would be easy enough to make if you knew someone with a lathe. Just drill and tap the ends of a long piece of aluminum bar or thick walled tube. If you already have the currie setup then you have a perfect template.
Offline Mr. Easy
  • Administrator
    • 72 scamp
« Reply #770 on: August 16, 2017, 01:16:51 PM »
 :yup: Tom........
Offline MassJK
« Reply #771 on: August 16, 2017, 01:24:52 PM »
It was an oddball grade if I remember  correctly
Offline A new level
« Reply #772 on: August 16, 2017, 03:44:36 PM »
My RK is aluminum. At F&F Mike said he watched it hit the front diff cover and bounce right back. Too bad my steering stabilizer didn't lol
« Reply #773 on: August 16, 2017, 06:21:21 PM »
I have an alumiflex as a spare that fit's my Currie system  :mrgreen:
Offline 50willysM38
« Reply #774 on: August 16, 2017, 06:36:06 PM »
Nothing. I'm not allowed to touch this one. ..........yet
2005 TJ, 35" BFG Mud Terrains, 4 inch currie lift,
Stock Willys M38
