Author Topic: Windstar Intake-Cowl Mod?  (Read 1436 times)
« on: January 02, 2017, 06:56:16 PM »
Has anyone done this? Due to the CJ grill, I need to do something with the stock airbox for clearance. Also, the stock YJ airbox has an "intake"  attached to the grill and that went away with the CJ grill.  I was first going to buy a cheap chrome tube and cone filter, but I would be gaining clearance and getting hot, dusty air. I'm definitely not spending $250 for a K&N CAI, so I found the Windstar mod. You get clearance, cold air from the cowl and you can use paper off-the-shelf filters.
Online MassJK
Re: Windstar Intake-Cowl Mod?
« Reply #1 on: January 02, 2017, 07:09:24 PM »
that looks clean
« Reply #2 on: January 02, 2017, 09:14:33 PM »
That's sexy !!!
« Reply #3 on: January 03, 2017, 09:11:39 AM »
I run an open air paper filter because I converted to TBI from carb.  It has the normal 4BBL. size neck , I think it 5.5" . Anyone know of a cone that would fit over that so I could do something like this ?   FjR68
« Reply #4 on: January 03, 2017, 09:18:27 AM »
Apparently this is a really common mod on the TJ's. I know tons of XJ guys run cowl intakes. I was planning to do so on the silver Jeep. I might see if this system can be made to work on the XJ as well. Looks like a very clean install.
« Reply #5 on: January 03, 2017, 11:57:22 AM »
I like that set-up!  Apparently it drastically decreased your air intake temperature...
« Reply #6 on: January 03, 2017, 05:13:15 PM »
I'm bummed, because this is apparently a TJ thing and not so easy on a YJ because of the cowl design.
« Reply #7 on: January 03, 2017, 05:16:29 PM »
if you ran a 4 banger you'd have PLENTY of room LOL
Offline MattG
  • Probie of the year!
« Reply #8 on: January 03, 2017, 06:08:49 PM »
true words!
« Reply #9 on: January 03, 2017, 06:14:15 PM »
looks like a Ranger air filter assembly...
Offline Miley Cyrus
« Reply #10 on: January 03, 2017, 08:28:42 PM »
That is what I have been looking at replacing my spectre cowl intake with because it uses normal intake filters.
Offline Johny Pornstash
« Reply #11 on: January 03, 2017, 09:18:27 PM »
Sweet! Maybe you can figure something out!
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
« Reply #12 on: January 04, 2017, 08:15:14 AM »
 If anyone can figure it out, I'm sure you can...
 You can make it a YJ thing...   :razz: :razz: :razz:
Profile for Team_Oscar
Quote from: Theo Maassen
Offline beaker
  • chillin and grillin
« Reply #13 on: January 06, 2017, 12:07:58 PM »
run paper filters, those k&n do not clean the air as well as regular paper.  I spent years designing filtration systems.  the oil dipped fiber filters let through a lot more dirt than paper.  They don't clog but that is their only benefit.  Just replace the paper with a new one and keep going.
« Reply #14 on: January 06, 2017, 03:47:37 PM »
On my 98 5.2L grand cherokee it had a standard 4 inch throttle body with a plastic horn coming off it.  I took out the airbox and ran a cone filter on the end of the horn for a while. Like Beaker said, the engine would stall at idle after a while and I would have to clean out the throttle bodies with a tooth brush and carb cleaner because there would be black dust caked on the sides.  I went back to the paper filter and air box and never cleaned the throttle body again.
I think that air horn would work for you if you could find one,.  It was not very tall where it connected to the throttle body.
« Reply #15 on: January 08, 2017, 11:01:19 PM »
The YJ cowl has the drain tube and it is the same area that is the intake for cabin air. I have decided to not run a top, even in the winter, just a safari top and a windjammer with doors, so cutting the intake into the cowl should be OK.
I still may just do something under the hood. I read that some have used this paper filter instead of the cotton K&N type.
https://www.amazon.com/gp/product/B000C9TBUO/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Offline joe98tj
« Reply #16 on: January 18, 2018, 08:51:49 AM »
I'm looking to do this to mine but before I head out to a junkyard or just order one off of ebay is their any specific year for the windstar or ranger this needs to come from? None of the write ups I read specify one
Mean, Green, Sticker Machine
« Reply #17 on: January 18, 2018, 09:11:44 AM »
2000 Windstar, not sure about Rangers
Offline joe98tj
« Reply #18 on: January 18, 2018, 09:15:47 AM »
Thanks rey!
« Reply #19 on: January 18, 2018, 10:11:16 AM »
Mid-90,s Ranger. There’s one in my shed up for grabs.
Offline joe98tj
« Reply #20 on: January 18, 2018, 10:17:24 AM »
The intake or a whole ranger?
« Reply #21 on: January 18, 2018, 10:28:22 AM »
Damn you have a big shed
« Reply #22 on: January 18, 2018, 10:33:11 AM »
Intake only, don’t be ridiculous. I’d sell it vice storing it. I’m a capitalist...
Offline joe98tj
« Reply #23 on: January 18, 2018, 10:39:09 AM »
I'll take it if you're getting rid of it
« Reply #24 on: January 18, 2018, 12:00:20 PM »
Its yours...
