Author Topic: TJ Body Mounts.  (Read 1301 times)
Offline Broken99TJ
    • http://www.objectriver.net
Re: TJ Body Mounts.
« Reply #25 on: March 27, 2017, 09:02:27 AM »
Quote
So your not concerned that those pop rivits will fail and rip out when the frame flexes?
Nope
Offline RobTJ
Re: TJ Body Mounts.
« Reply #26 on: April 10, 2017, 01:03:53 PM »
I would have suggested these instead of the home depot solution.
http://www.rustrepairpatch.com/store/c1/Featured_Products.html
So I just ordered the 2 middle and 2 rear sleeves from them.   Packaged together its $199
They should be here by Wed.
Re: TJ Body Mounts.
« Reply #27 on: April 10, 2017, 01:26:48 PM »
Something to consider; go to Moab, wheel, have fun, buy a house, stay there rust free....
Offline Broken99TJ
Re: TJ Body Mounts.
« Reply #28 on: April 10, 2017, 01:27:59 PM »
Web site says $79 a piece? Your still going to have to loosen all the other body mounts to jack the body up.  Out of 11 mounts only 3 could be loosened. The driver mount by the shock, I just cut off and said screw it.
Offline RobTJ
Re: TJ Body Mounts.
« Reply #29 on: April 10, 2017, 01:45:57 PM »
Offline Broken99TJ
Re: TJ Body Mounts.
« Reply #30 on: April 10, 2017, 07:29:24 PM »
For $300 you can buy the full torque boxes. https://raybuck.com/product/1997-06-jeep-tj-wrangler-full-length-torque-boxfloor-support-drivers-side/?gclid=COnWq4eQm9MCFQaHswodlnQCIA
It's not worth it, I'm just beating on it in the woods. These TJ's are a PITA. If I was building a show Jeep, like Tom, that would be different.
Offline RobTJ
Re: TJ Body Mounts.
« Reply #31 on: April 10, 2017, 07:44:18 PM »
I have to loose all the mounts regardless.
And to replace them, you have to take the body off to get to the inside spot welds
Offline harryhood
Re: TJ Body Mounts.
« Reply #32 on: April 10, 2017, 08:08:44 PM »
I look forward to seeing what you have to say about them. The middle mounts in my tj are toast. I'm thinking of using those for the repair.
Re: TJ Body Mounts.
« Reply #33 on: April 10, 2017, 10:33:44 PM »
I'm curious too
Offline Broken99TJ
Re: TJ Body Mounts.
« Reply #34 on: April 11, 2017, 09:17:14 AM »
I am curious to know how many of the 11 body mounts that you can loosen  :question:
Re: TJ Body Mounts.
« Reply #35 on: April 11, 2017, 09:46:20 AM »
Psssh show jeep, I wish
all the bolts will come loose with an .040 wheel
Offline harryhood
Re: TJ Body Mounts.
« Reply #36 on: April 11, 2017, 09:47:44 AM »
Rob, would mind making a sketch with basic measurements of the repair pieces once you get them? I think I'll see if i can make up my own with my brake
Offline RobTJ
Re: TJ Body Mounts.
« Reply #37 on: April 11, 2017, 09:55:04 AM »
Sure
Re: TJ Body Mounts.
« Reply #38 on: April 11, 2017, 09:57:16 AM »
LOL
the tough part is the dimple, you need the dimple for the body mount puck to fit in
The dimple also adds strength tot he sheet metal
Offline MassXJ
Re: TJ Body Mounts.
« Reply #39 on: April 11, 2017, 10:03:24 AM »
Spin him a couple pucks to use in the press
Offline harryhood
Re: TJ Body Mounts.
« Reply #40 on: April 11, 2017, 10:05:38 AM »
There is no dimple on the patch. They say (in the video Rob posted) the dimple is what holds moisture and causes the area to rust out.
Offline RobTJ
Re: TJ Body Mounts.
« Reply #41 on: April 11, 2017, 10:06:26 AM »
They make them both flat and dimpled.
They recommend the flat if you are going to install a rocker guard or step
Re: TJ Body Mounts.
« Reply #42 on: April 11, 2017, 10:11:41 AM »
dimple die without the hole in the center
Re: TJ Body Mounts.
« Reply #43 on: April 11, 2017, 10:11:55 AM »
that makes sense
Offline MassXJ
Re: TJ Body Mounts.
« Reply #44 on: April 11, 2017, 10:38:03 AM »
Use a pin on one side for line up. Same size as the bolt
Re: TJ Body Mounts.
« Reply #45 on: April 11, 2017, 10:38:40 AM »
I need a bigger lathe at home !
Offline RobTJ
TJ Body Mounts.
« Reply #46 on: April 13, 2017, 06:29:57 PM »
They arrived today.
Doug here's your sketch.
Offline harryhood
Re: TJ Body Mounts.
« Reply #47 on: April 13, 2017, 07:25:37 PM »
Thanks!
Re: TJ Body Mounts.
« Reply #48 on: April 13, 2017, 10:20:10 PM »
Wow they look like they are made out of thin soup can thickness stock!
Offline RobTJ
Re: TJ Body Mounts.
« Reply #49 on: April 14, 2017, 08:28:53 AM »
16 gauge
Any thicker and it would be difficult to put in a break
