Author Topic: Lots Of Rattle Coming From My Jeep's Rear  (Read 1173 times)
Offline JeepMM2
« on: February 07, 2017, 03:24:31 PM »
For some time now, there has been a rattle noise emanating from the back of the Jeep. I was told it was possibly the rear sway bar links and bushings. But after googling it, I found a thread on the Jeep.com forum on this rattle noise. Some seemed to suggest shocks were the culprit. I checked the links yesterday and nothing looks loose. Anybody have the same problem?
"I'M THE 82nd AIRBORNE, AND THIS IS AS FAR AS THE BASTARDS ARE GOING."
PFC Martin, 325th Glider Infantry Regiment  Dec. 23, 1944
Re: Lots Of Rattle Coming From My Jeep's Rear
« Reply #1 on: February 07, 2017, 03:26:33 PM »
Can you replicate the noise by jumping on the rear bumper? If so, have someone do that while you look under the Jeep. Try grabbing the various suspension components, you may be able to feel which one is moving and making noise if you can't see it.
Offline Imnotcassie
  • Newbie
« Reply #2 on: February 07, 2017, 03:53:58 PM »
I had a rattle and it was driving me crazy because I couldn't hear it all the time and couldn't find it.  Finally .... it was the heat shield above the muffler.
-Cassandra
« Reply #3 on: February 07, 2017, 04:40:21 PM »
Another way to check is have someone outside the jeep listening as you move forward and backward quickly from a stop. That may be enough to isolate the source of the noise.
Offline XtraChrisP
  • Yup
« Reply #4 on: February 07, 2017, 05:48:05 PM »
Have you tried removing the empty cans of spray paint from your trunk?
« Reply #5 on: February 07, 2017, 06:22:33 PM »
Lol
Offline JeepMM2
« Reply #6 on: February 08, 2017, 02:47:42 PM »
I opened the tailgate and used that to push down on several times to simulate road travel. There's a noise similar to what I hear driving. Unfortunately I can't see what it is.
Empty spray cans? Tom held on to those for the deposits.
« Reply #7 on: February 08, 2017, 03:13:34 PM »
you need a second person to listen while you do that, or vice-versa.
« Reply #8 on: February 13, 2017, 08:40:44 PM »
I wouldnt consider a shock or sway bar to be a rattle. That would be a thunk ! Solid.  The heat shield is a rattle.   Exhaust usually touching something will rattle.   FjR68
Offline JeepMM2
« Reply #9 on: February 14, 2017, 12:09:03 AM »
It's definitely coming from the right side. I had a drs apptmt this am and drove there on a very pockmarked road. At times it feels like I'm going to lose something. Just have to find somewhere to bring it or someone to listen.
Offline Broken99TJ
    • http://www.objectriver.net
« Reply #10 on: February 14, 2017, 06:49:14 AM »
Body Mounts  :eek:
« Reply #11 on: February 14, 2017, 07:04:49 AM »
Im in Enfield if your close I can take a look .     FjR68
« Reply #12 on: February 14, 2017, 08:10:22 AM »
Sounds like something may have loosened up after your frame repair.  Most likely exhaust though.
Offline JeepMM2
« Reply #13 on: February 14, 2017, 09:23:09 AM »
I've had this rattle way before the frame repair. Maybe it is the exhaust.
Offline Greenhorn
« Reply #14 on: March 05, 2017, 08:42:05 AM »
Did you ever find this Mark?
check if somebody put a huge zip tie on your driveshaft...lol  :mrgreen:
 -Thomas Jefferson
Offline JeepMM2
« Reply #15 on: March 05, 2017, 01:27:00 PM »
Nope. It sounded more intense this morning, maybe because of the cold. The bitter cold also makes the initial whirring sound coming from the transmission more pronounced. Since I feel sometimes like I'm losing it I need a psychiatrist who drives a TJ!  :eek:
Offline DVal
  • Newbie
« Reply #16 on: March 13, 2017, 12:04:32 PM »
Heat Shield?
Offline JeepMM2
« Reply #17 on: March 13, 2017, 12:22:53 PM »
Hmm.
Sent from my LG-K425 using Tapatalk
Offline Johny Pornstash
« Reply #18 on: March 14, 2017, 12:13:17 AM »
Cold  would stiffen up rubber bushings... maybe a exhaust?
« Reply #19 on: March 14, 2017, 07:33:33 AM »
busted u-joint?
Offline JeepMM2
« Reply #20 on: March 16, 2017, 05:48:29 PM »
There are a couple of distinct noises. One when I let out the clutch, sounds not from the front but the rear. Then there's the familiar sound like no shocks absorbers.
