Author Topic: diff cover or skid?  (Read 1191 times)
Offline BC Miller
Re: diff cover or skid?
« Reply #50 on: April 03, 2017, 07:08:36 AM »
I had zero issues with my PS cover. 3/8 drive socket fit no problem.
3/8"? Interesting.  The bolts that came with my cover had 1/2" heads.  If they were 3/8", I probably would have had just enough clearance.
« Reply #51 on: April 03, 2017, 06:33:34 PM »
3/8" drive bright socket. Where you using a 1/2" drive or a impact? Both? In other words I used a thin walled socket.
« Reply #52 on: April 03, 2017, 06:37:02 PM »
eric helped me out....great guy....I will be buying more from ORE in the future
Eric is a good dude. I've called for a part ( they have my CC on file  :cool: ) and ended B.S.ing for a 1/2 hour lol
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #53 on: April 19, 2017, 02:22:08 PM »
God bless America
PLAN YOUR WORK
WORK YOUR PLAN (MAKE IT WORK!)
01001001 01110100 00100111 01110011 00100000 01010100 01101111 01101101 00100111 01110011 00100000 01100011 01101001 01110010 01100011 01110101 01110011 00101100 00100000 01110100 01101000 01100101 01111001 00100000 01100001 01110010 01100101 00100000 01101000 01101001 01110011 00100000 01101101 01101111 01101110 01101011 01100101 01111001 01110011 00101110
41 6c 61 6e 20 68 61 73 20 46 6f 72 20 73 61 6c 65 0a 4f 6e 65 20 63 69 72 63 75 73 2c
Offline Mr. Softy
« Reply #54 on: April 19, 2017, 09:01:13 PM »
Not sure if its in the instructions but measure the fluid yer putting in to factory spec, the fill is higher on those = overfill... ask me how I learned that a few years ago...
« Reply #55 on: April 19, 2017, 09:10:54 PM »
  This!  around 1"-1.5" below the fill hole on those depending on your pinion angle  :wink:   zip tie works good as a dipstick...
Offline Abrasion Sleeve
« Reply #56 on: April 20, 2017, 07:23:27 AM »
Yes, either keep track of the amount of fluid and just add the capacity rated for the axle or fill to the bottom of the axle tubes, yes a tie wrap works well as a dip stick! :mrgreen:
« Reply #57 on: April 20, 2017, 07:29:17 AM »
fill it to the top, It will find its happy spot eventually
Offline harryhood
« Reply #58 on: April 20, 2017, 07:36:29 AM »
That's what I told her but she didn't believe it
« Reply #59 on: April 20, 2017, 07:37:39 AM »
 :rotflmao:
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #60 on: May 06, 2017, 01:59:51 PM »
God bless America
PLAN YOUR WORK
  • Probie
« Reply #61 on: May 07, 2017, 10:11:19 AM »
I had the same question on the tera flex ones.....could only get a quart in rear,,,called eric he said to fill to factory specs through the top hole of the diff cover...pinion angle misleads you a bit..
