Author Topic: Another jeep goes under the knife  (Read 1464 times)
« on: March 29, 2017, 08:02:31 AM »
After the Summit run on Sunday Rob dropped off his jeep with a pile of steel tube. What could that be ???
After a few hours the jeep was looking a little empty inside..
Monday was spent prepping tubes for welding, and eyeballing how everything was supposed to fit. It was observed that the passenger side did not line up as well as the drivers side. After looking over the entire jeep; it was realized that the body mounts had broken through the torque tubes, causing the body to settle.
Starting with the passenger side, the main hoop was put into place excluding the B pillar. The same was done on the drivers side. Once the front and rear were tacked into place, all the other tubes could be fitted.
By quitting time Wednesday, all the tubes were in except for the harness bar and the B pillars ( waiting on parts.
Re: Another jeep goes under the knife
« Reply #1 on: March 29, 2017, 08:03:29 AM »
More ..
« Reply #2 on: March 29, 2017, 08:04:21 AM »
Even More
« Reply #3 on: March 29, 2017, 08:05:33 AM »
Maybe a live feed
Offline HankD
« Reply #4 on: March 29, 2017, 08:07:11 AM »
Spyder kit? Does it fit better than Steves?
« Reply #5 on: March 29, 2017, 08:18:48 AM »
Nice! I'm thinking it went together pretty easily as he only has had it a few days. My poison spider kit went together easily.
Offline RobTJ
« Reply #6 on: March 29, 2017, 08:21:50 AM »
Tom does awesome work!!
If it wasn't for PS forgetting to package a couple of parts,  he'd probably have it completed already.
« Reply #7 on: March 29, 2017, 09:08:56 AM »
Looks like it goes together much easier than my A-Z cage, which every tube had to be trimmed.
I like that design, down the road, when I'm board I was going to bend up a similar cage for the White Jeep
« Reply #8 on: March 29, 2017, 10:29:32 AM »
Looks good!
Offline Maser
  • Two half nothings is a whole nothing.
« Reply #9 on: March 29, 2017, 06:55:30 PM »
Great Job!
I\'m [was] the paintball guy
« Reply #10 on: March 29, 2017, 07:08:56 PM »
That's such a badass kit!
« Reply #11 on: March 29, 2017, 07:09:49 PM »
Tom's got some mad skillz
Online MassJK
« Reply #12 on: March 29, 2017, 07:18:59 PM »
not sure kissing ass moves you up the list.  cant hurt
« Reply #13 on: March 29, 2017, 07:59:58 PM »
so long as I ain't hustlin backwards
Offline Miley Cyrus
« Reply #14 on: March 29, 2017, 08:17:44 PM »
The ps kit goes together way quicker and easier than my cage my cage took a lot of finessing and noodling to get it to work properly tom definitely does great job and works miracles
Offline RobTJ
« Reply #15 on: March 30, 2017, 07:29:22 AM »
I was planning on getting the same KoZ cage, but the guy decided to go MIA
Wouldn't return phone calls or emails.
So I made the switch to PS
« Reply #16 on: March 30, 2017, 08:33:14 AM »
How accurate are the provided knotches?
« Reply #17 on: March 30, 2017, 02:07:43 PM »
The notches are absolutely beautiful ! ill take some pictures of the fitment when i get home
Offline Lambchop
« Reply #18 on: March 30, 2017, 02:39:22 PM »
Wait you have access to a tube bender?
« Reply #19 on: March 31, 2017, 08:49:24 AM »
Another night in the garage, More progress has been made !
Rob stopped over last night, We took measurements for where the harness bar needed to be placed. With the help of Steve B, we pulled the cage out. The cage is now fully welded awaiting paint.
« Reply #20 on: March 31, 2017, 08:50:21 AM »
More
« Reply #21 on: March 31, 2017, 08:50:56 AM »
Because you're "Super Tom"!
« Reply #22 on: March 31, 2017, 08:51:34 AM »
I wouldnt go that far
Offline RobTJ
« Reply #23 on: March 31, 2017, 10:17:22 AM »
Well you definitely have mad skills.
Offline BC Miller
« Reply #24 on: March 31, 2017, 11:04:01 AM »
Very nice.  Any idea what all that steel weighs?
