Author Topic: People that weld shouldn't build Jeeps.  (Read 654 times)
Re: People that weld shouldn't build Jeeps.
« Reply #25 on: April 04, 2017, 12:25:55 PM »
Like everything the intended purpose needs to be considered. If the vehicle is a daily driver and fuel consumption is a factor, then yes every pound makes a difference. However as you try harder and harder trails those light duty components see more stress. Take rubber bushings on the control arms for instance. for most people rubber bushings work great, however there is a reason they are not used on both ends of a long arm kit. the rubber bushings cannot handle the flex reliably, so you switch to a heim or johnny joint. I would bet a johnny joint is double the weight of a rubber bushing. Multiply that added weight by 16 ( 2 joints per arm ) Bam added tons of weight.
How about something simple like a drive shaft. we all convert to a slip yoke eliminator and double cardon shaft. I would bet the double cardon joint is added weight.
Throw 2 arb's into an axle, those bastards are heavy
If your building a non one off jeep, there are not a lot of weld on components that add more weight than bolt on mods would. I bet I could make a tj weigh just as much as mine with just bolt on parts
The other consideration is cost vs weight. Im cheap, if i can save a few dollars and make it myself I will. With that comes alot of over building, since I dont know what will fail. Attached is a photo of my skid plate for tranny and oil pan. total cost FREE because I already had the plate from another project. The entire skid plate is 1/4 plate. Is it heavy, hell yeah. will it break, hell no. A pre made skid would be lighter but cost way more ( 350 for comparable)
Now I did go over kill with my link material
Weigh your jeep, you will be surprised
Offline Abrasion Sleeve
« Reply #26 on: April 04, 2017, 01:11:31 PM »
Awesome!
I'm with Tom, build it so it don't break on the trail!  Nothing worse than holding up a trail ride because you did something stupid your rig wasn't built for. Or you wheel your rig without proper maintenance and a good once over before hitting the trail! :rolleyes:
If you are worried about MPG than the Jeep is not for you.  If your into Jeeps and love them for what they are, don't pay attention at the pump!  I haven't paid attention to MPG since my 20s and I'm happier for it.  NONE of my vehicles are fuel efficient.  If it bothers you that much, get a DD Civic or scooter!
F250 6.4L=12-16 MPG depending on load, 10-12 MPG with camper and Jeep in tow.
TJ 4.0L=(I'm guessing) 14 MPG 35s with 4.10 gears.
Ford Edge 3.6L AWD=16-19 MPG.
« Reply #27 on: April 04, 2017, 01:45:24 PM »
Quote
5100 pound
  :eek:
5100 may sound like a lot; but the jeep will do 80 down the highway, comfortable enough for a multiple hour drive, and still goes good in the woods.
It really needs a V8.
as long as the power / gearing is there to move the weight, I dont see overall rig weight as an issue. If anything a heavier vehicle with the same aired down contact pattern on the rocks will go better... More gription bro
« Reply #28 on: April 04, 2017, 01:47:44 PM »
I have to say  that over the years the Red Jeep has seen many incarnations.
But,  I have never said to myself "I wish I had the 6 cylinder back, instead of that damn 401", ever.
« Reply #29 on: April 04, 2017, 01:51:27 PM »
LOL !!!!!
Offline BC Miller
« Reply #30 on: April 04, 2017, 02:13:57 PM »
Good discussion.  I don't disagree with (most) of what's being said.  I'm just pointing out that pure physics say that if you have to move more weight, you're going to cause more stress doing it.  If the components being added/replaced are worth the added weight, then by all means do it (my JK certainly weighs more than stock).  But if you're adding something that adds little or no benefit, then why bother?
As far as MPG, I've owned a few vehicles that have gotten worse than my JK, so I'm use to low gas mileage.  I'm just saying why waist the MPGs if you don't have to?  Again, "weigh" the benefits.
That is all.
Offline harryhood
« Reply #31 on: April 04, 2017, 02:19:17 PM »
I just lost 5 iq points reading this thread
« Reply #32 on: April 04, 2017, 02:21:01 PM »
im gonna sell it all and buy a prius and trailer a moped
« Reply #33 on: April 04, 2017, 03:28:08 PM »
« Reply #34 on: April 04, 2017, 03:29:05 PM »
« Reply #35 on: April 04, 2017, 03:30:16 PM »
By Law Change: "Must own a Prius"
Offline BC Miller
« Reply #36 on: April 04, 2017, 03:38:45 PM »
Well, it's been fun being a member of this club while it lasted.
« Reply #37 on: April 04, 2017, 04:39:53 PM »
WOW, thin skin...
I thought this was a day of fun and lively conversation...  :razz:
Online XJRV-Maki
  • salt no carry
« Reply #38 on: April 04, 2017, 05:08:43 PM »
But think of all the weight you'd save in pop rivetzzz  :razz:
*I can't believe I'm the 1st one to pop broken over teh rivetz, what's wrong with you guys!  :rolleyes:
And I'm all for light rigs. At the end I was ripping body panels off the MJ and even with an open D30 I would have taken anyone on in a timed race up OFR or MB, I 1 shot all those ledges or at most a set-up and a bump :mad02:
Proles and animals are free
Online MassXJ
« Reply #39 on: April 04, 2017, 05:44:37 PM »
Roofing tar and pop screws is not always the best repair
Online XJRV-Maki
  • salt no carry
« Reply #40 on: April 04, 2017, 05:49:15 PM »
That self-adhesive roof flashing from HD was genius...kept my feet from falling out the bottom
Online MassXJ
« Reply #41 on: April 04, 2017, 06:02:44 PM »
I wish Tom didn't kill broken.  A high lift could have fixed it
Offline Paul'TheGuest'W
« Reply #42 on: April 04, 2017, 06:35:21 PM »
Nice.
Offline BC Miller
« Reply #43 on: April 04, 2017, 06:53:18 PM »
WOW, thin skin...
Easy, Pat.  All is good.  I guess my sarcasm doesn't come across well in print.  Trust me, I was joking.  And my skin is thicker than it looks.  But I still would never buy a Prius.
« Reply #44 on: April 04, 2017, 10:29:17 PM »
WOW, thin skin...
Hey, what's wrong with owning a Prius?
Offline Broken99TJ
    • http://www.objectriver.net
« Reply #45 on: April 05, 2017, 05:34:04 AM »
Quote
Quote
Adding more floor mats, worked good also  :eek:
It worked great until a log came through the floor and almost got my leg.  :eek:
Quote
No, The North Adams police were looking for me, and I couldn't go to Big Y any more  :rotflmao:
