Author Topic: Need a good transmission shop western CT  (Read 293 times)
Offline stan98TJ
« on: April 05, 2017, 09:01:00 AM »
Hey guys,
Transmission on my Ranger is blown. Dunno if it would be cheaper to rebuild or replace. Won't go in Drive, only 2nd gear and reverse work. Need a shop close(ish) to me (Newtown). Anyone know of a reputable shop that won't screw me on the project?
Thanks
98 4cyl. 4.56 gears, 35" Maxxis Treps 2.5"OME springs+long travel shocks+ 1" BL, IronMan Fab 4x4 arms, Currie+IronMan steering, 8.8 rear,HP D30 sleeved+Eaton, RCVs,rear ARB,LODrear bumper. TO DO: Diesel Swap, Atlas4spd
The old lady hates it :)
-If you can read this, don't roll me over. I don't have any $$ left to fix it-
Re: Need a good transmission shop western CT
« Reply #1 on: April 05, 2017, 09:15:27 AM »
Many times its the valve body gasket fixes it.
« Reply #2 on: April 05, 2017, 09:50:05 AM »
What year ranger ? have you checked it with a good code reader ? could be a range selector switch or a bad solenoid. those are fairly good transmissions, I wouldn't assume its blown. If it has reverse it should have 1st, they work off the same drum.
« Reply #3 on: April 05, 2017, 09:51:04 AM »
If its a v6 ranger aftermarket is very slim for that tranny, your better off buying a good used out of a junk yard
Offline Prof_Oaks
  • Probie
  • Newbie
« Reply #4 on: April 05, 2017, 11:52:11 AM »
Don't know how far your willing to travel but Hi-Tech transmissions in East Longmeadow MA is a great shop.  I've gone there for all my trans needs and they are very quick, very experienced and have reasonable prices.
317 Somers Rd, East Longmeadow Ma 01028
Offline stan98TJ
« Reply #5 on: April 06, 2017, 02:04:31 PM »
It's an 07 4cyl 2wd auto. Was shifting hard 1st-2nd for a little while. Tried Lucas. At times you would be stopped at a light and it wouldn't go until you shifted back to park and then to Drive again...or sometimes you'd have to put it in Park and cut the engine and start it back up. When the gear selector is in Park or Drive all you hear is a spinning sound. Only gear that works is Reverse and 2nd
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
Profile for Team_Oscar
Quote from: Theo Maassen
Offline redtj
« Reply #7 on: April 07, 2017, 11:39:17 AM »
Lou in Oxford, he works out of his house  203-881-0068
2002 TJ  35"km2  d44 locked 8.8 spool 4.10
2011 GMC 2500HD  tow vehicle
Offline stan98TJ
« Reply #8 on: April 07, 2017, 01:41:04 PM »
My buddy James just recommended him
Offline stan98TJ
« Reply #9 on: April 07, 2017, 01:45:39 PM »
You got another number for him? That one doesn't work.
« Reply #10 on: April 09, 2017, 08:55:31 AM »
My Explorer Spot Trac had the same 5spd auto I believe.  What your describing sounds like the repair I went through. Check that there isnt a silent recall for this. My Trans guy knew about it. They have an upgraded one piece shift solenoid gasket to replace the multi layered one that delaminates  through time , Mine was just over 100k when it started for me.   Hope you get it fixed    FjR68
Offline redtj
« Reply #11 on: April 10, 2017, 02:37:23 PM »
Stan try 203-881-1932
Offline stan98TJ
« Reply #12 on: April 11, 2017, 05:15:15 PM »
Thanks for the info!
Offline Maser
  • Two half nothings is a whole nothing.
« Reply #13 on: April 12, 2017, 03:15:40 AM »
Jerry's transmissions here in Danbury is really good.  he rebuilt my tranny in my my old WJ. he gave me about 10 more years out of my Jeep LOL
http://jerrystransmissionsdanbury.com/
I\'m [was] the paintball guy
« Reply #14 on: April 12, 2017, 10:39:22 AM »
X2 on Jerry's - they did a great job on my YJ's transmission in 1997.  20 years later and it's still going strong!
