Author Topic: ISO Dana 30 High Ratio Carrier  (Read 444 times)
Online RedJeepster1
« on: April 06, 2017, 10:16:49 AM »
Hey guys,
Wondering if anyone in the club has a high ratio carrier for a dana 30? Regearing my HP30 soon and will need a new carrier since the current gears are 3.55.
Open to whatever you have, open, limited slip, locker, just looking for something used but in decent shape.
Offline RobTJ
Re: ISO Dana 30 High Ratio Carrier
« Reply #1 on: April 06, 2017, 10:30:55 AM »
I might still have an open carrier kicking around.
It was set up for 3.73s
Online RedJeepster1
« Reply #2 on: April 06, 2017, 11:49:14 AM »
That would work if you still have it. The carrier break was between 3.55 and 3.73, so to go any higher I need the other carrier.
Online RedJeepster1
« Reply #3 on: April 08, 2017, 08:03:03 AM »
Anyone else maybe have a carrier on a shelf somewhere? 4.56 gears are on the way! As well as some other goodies. Updates to come later on in another thread.
« Reply #4 on: April 10, 2017, 07:33:15 AM »
I have a complete XJ HP30 no Vac . Control arms , steering linkage , disk to disk , with 3.73s .  300 buks come get it in Enfield       FjR68
Online RedJeepster1
« Reply #5 on: April 10, 2017, 08:00:26 AM »
Thanks for the offer but no thanks. I have an HP30 already and will be regearing, running different knuckles, steering, and brakes, and going long arm, as well as moving the spring perches so the only thing there I would have use for is the carrier.
Online RedJeepster1
« Reply #6 on: April 13, 2017, 11:06:47 AM »
So nobody has a carrier sitting around anywhere? Probably just going to order one if not. Gears should be delivered today.
Offline RobTJ
« Reply #7 on: April 13, 2017, 11:45:25 AM »
I'll check tonight.
« Reply #8 on: April 13, 2017, 11:53:29 AM »
e locker
Offline Mr. Clean
« Reply #9 on: April 13, 2017, 11:59:56 AM »
I've seen New ones for less than $80 shipped...
Online RedJeepster1
« Reply #10 on: April 13, 2017, 12:10:07 PM »
I'll check tonight.
Thanks!
e locker
I don't think that's in the budget....
In my house that's a week worth of groceries!
« Reply #11 on: April 13, 2017, 12:47:24 PM »
I dump that in ammo and competition fees every week! :eek:
Online Greenhorn
« Reply #12 on: April 13, 2017, 02:24:32 PM »
This one here is toast. Cross pin hole is NG.
If you get an unknown one this is how to check them.
I used to think they just turned more material off for the thicker ring, but the casting is a different part number too.
 -Thomas Jefferson
Offline mustangx
  • Newbie
« Reply #13 on: April 13, 2017, 02:29:46 PM »
I'd check with ricky at barret fab or over at dmr. those guys do a lot of gear swaps and always have carriers etc around. ricky hooked me up with a d44 carrier last week for 456 gears. chad longo at motorsports in ellington is another 1 to ask.
05 TJ, Rocky Mountain Edition. 4"suspension, 1"body lift, tummy tuck, 37's,456 gears, chrome alloys front and rear, sye and custom driveshafts, over the knuckle steering. fox long travel shocks, fully armored
Online RedJeepster1
« Reply #14 on: April 13, 2017, 06:32:56 PM »
Thanks. I'll call around tomorrow if nothing turns up.
Offline RobTJ
« Reply #15 on: April 13, 2017, 06:43:06 PM »
Pm sent
