Author Topic: toe in question  (Read 2605 times)
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
Re: toe in question
« Reply #25 on: May 01, 2017, 06:08:32 PM »
How was Harris Mountain?
This is an AWESOME place.  40 + showed up to wheel.    our club should look in to having an event there.
Elizabeth Saunders,  the home owner, was there with her two sons.  She was very appreciative of the 4 wheel Community for all the donations.
Her sons (in their 20's) have spent a lot of time on the trails.   Trails are very well made. and there is some thing for everyone.
Thanks you to:
Ian
Todd (how also helped lead)
and the Club
NEJeep has left a good impression.
Re: toe in question
« Reply #26 on: May 01, 2017, 06:25:49 PM »
Thanks you to:
Ian
and the Club
 :sign_hijack:  Sounds good to me! Was disappointed I missed it
Re: toe in question
« Reply #27 on: May 01, 2017, 06:27:30 PM »
thinking of adding the teraflex tie rod, lifetime warranty and beefy....dont really know if i need the upgraded drag link from them.. but still researching....all good
If you want to check out what I did PM me, we can meet up.
Re: toe in question
« Reply #28 on: May 01, 2017, 07:40:52 PM »
cool appreciate it....definitely keep that in mind
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
Re: toe in question
« Reply #29 on: May 01, 2017, 07:49:13 PM »
Thanks you to:
Ian
and the Club
Sorry for HIJACKING this,  but when others aren't keeping UP TO DATE some times you just have to post things EVERYWHERE. :rant:
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
Re: toe in question
« Reply #30 on: May 01, 2017, 07:52:51 PM »
Steve just shut up  :lipsrsealed: :lipsrsealed: :lipsrsealed:
Offline Broken99TJ
    • http://www.objectriver.net
Re: toe in question
« Reply #31 on: May 02, 2017, 07:15:14 AM »
Quote
Hey what are you guys running for tie rods n drag links...stock or not?
On Broken I sleeved the tie-rod with a Home Depot pipe. :eek: It acted like a roller also. Never had a problem after that.  :rotflmao:
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
Re: toe in question
« Reply #32 on: May 02, 2017, 08:48:57 AM »
I use one From RUSTY's OFF-ROAD  then welded a pip over it for a sleeve
Re: toe in question
« Reply #33 on: May 02, 2017, 09:00:25 AM »
Hmm great idea , kinda armored it
Re: toe in question
« Reply #34 on: May 02, 2017, 09:09:05 AM »
Before you "Sleeve" you Tie Rod, be sure you have the clearance and you are not going to interfere with the Diff Cover.  If your tie rod hits the diff cover you are adding stress to your TRE and the only way to fix this is to adjust the stops which decreases your turning radius.
Just sayin.
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
Re: toe in question
« Reply #35 on: May 02, 2017, 10:24:23 AM »
Just sayin.
He's right, I did have to noch out a spot for the Track-bar bolt so when I turn all the way to the right, so it wouldn't hit.
Re: toe in question
« Reply #36 on: May 02, 2017, 10:26:03 AM »
just go with one ton steering
Offline MassJK
Re: toe in question
« Reply #37 on: May 02, 2017, 10:31:18 AM »
ya that always works
Re: toe in question
« Reply #38 on: May 02, 2017, 10:35:19 AM »
Yup lol
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
Re: toe in question
« Reply #39 on: May 02, 2017, 10:36:09 AM »
Offline 50willysM38
Re: toe in question
« Reply #40 on: May 02, 2017, 04:32:30 PM »
I'm thinking 5 ton next
Stock Willys M38
Re: toe in question
« Reply #41 on: May 02, 2017, 05:05:12 PM »
really interested in the tera flex tie rod and drag link kit....lifetime warranty ....
Re: toe in question
« Reply #42 on: May 02, 2017, 05:27:47 PM »
Might as well just do a full MRAP conversation
Re: toe in question
« Reply #43 on: May 02, 2017, 05:32:37 PM »
Teraflex makes good stuff and they won't have the clearance issues that come with the Rock Krawler. But I like how the RK is made from T651 aluminum so it will flex a little when hit.
Re: toe in question
« Reply #44 on: May 02, 2017, 06:45:00 PM »
I run a currie correctlync. spendy but good quality
Online JeepinMaxx
Re: toe in question
« Reply #45 on: May 02, 2017, 10:27:52 PM »
  Doug - I think that's what is in my newer TJ - $500 for the drag link & tie rod !  Does the tie rod ends use the stock D30 taper?
Re: toe in question
« Reply #46 on: May 03, 2017, 06:20:17 AM »
yes, stock taper. I also have a drivers side flip which raises the components up some.
It's not cheap but I also haven't broken on the trail and there is a lot less flex than the stock set-up.
Re: toe in question
« Reply #47 on: May 03, 2017, 07:17:16 AM »
Hey Kak , Please explain to me how toe will change adjusting the drag link ???????????   FjR68
Re: toe in question
« Reply #48 on: May 03, 2017, 08:39:05 AM »
I suck at ALL forms of math, but see for yourself.  I always set the steering wheel first, then adjust toe, then recheck the wheel, any other adjustments to the draglink you will affect the toe so you have to readjust.
Check your toe first, then adjust the drag link so your wheel is where you want it.  The Toe will change.
Offline RobTJ
Re: toe in question
« Reply #49 on: May 03, 2017, 08:50:17 AM »
This what happened to Bone's TJ this past weekend.
Before we reconnected the steering (after lift) we centered the steering wheel.
After correcting 2" worth of toe-in.   The steering will was at 3.
