Author Topic: TJ Door Surround Question  (Read 486 times)
« on: June 10, 2017, 09:19:11 PM »
I drove my new to me 1999 TJ to the M&G last night with the soft top on with no doors, windows...   On the highway, the door surrounds vibrated and jumped around.  Is there anything to hold them in place other than the tension of the soft top?
Offline Angrytj
  • Luciano
    • My YouTube channel
Re: TJ Door Surround Question
« Reply #1 on: June 10, 2017, 09:23:00 PM »
Do you have the pins that go through the cage to hold them in?
2005 Jeep Wrangler Rubicon
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #2 on: June 10, 2017, 10:43:07 PM »
yes, on the top there two screw in door frame holders
Offline Lambchop
« Reply #3 on: June 11, 2017, 08:27:47 AM »
Two screws with large round flat handles per surround as mentioned but there is also a rubber pad that goes between the tub and bottom pin that greatly helps reduce the vibes. Also it may only be a slight amount but the top front corner of the surround does slide in the corner of the windshield frame just a hair.
Two screws for top
Rubber for bottom
« Reply #4 on: June 11, 2017, 09:37:51 AM »
Two screws for top
Rubber for bottom
Looks like these are the parts I'm missing!  I'll have to drill holes in my aftermarket front roll cage for the knob/pins and try to source those and the rubber isolators
« Reply #5 on: June 11, 2017, 09:39:05 AM »
This is all too complicated for me. Lol
Offline MassJK
« Reply #6 on: June 11, 2017, 09:39:31 AM »
put a tarp over it
Offline Johny Pornstash
« Reply #7 on: June 11, 2017, 10:03:40 AM »
Just take the surrounds off and fold them and out em in back!
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #8 on: June 11, 2017, 11:39:22 AM »
 The rubber at the bottom is called a mukit cover
« Reply #9 on: June 11, 2017, 11:41:04 AM »
Thanks!  Each knob is $20!  Mucket rubber is $20 each!  I'm going to figure a DYI solution...
« Reply #10 on: June 11, 2017, 12:06:01 PM »
I think I have a few pair, I don't use them as someone....   :redface:  Welded handles in the way
ill take a look if you want to replace the home made ones.
« Reply #11 on: June 11, 2017, 12:22:34 PM »
Thanks Corey!
Offline Lambchop
« Reply #12 on: June 11, 2017, 03:13:16 PM »
If it helps you may wanna try it without the rubbers first since its really not that bad without them. The screws are the important part. Im just shocked you didnt loose one on the highway without the screws.
Offline Angrytj
  • Luciano
« Reply #13 on: June 11, 2017, 04:26:54 PM »
Yup, exactly what I was referring to. I may have these laying around since I have an aftermarket cage that the door surrounds fit snug on without the screws.
Ill report back.
« Reply #14 on: June 11, 2017, 04:47:12 PM »
They snap on the aftermarket bar pretty good but my top was up and probably held them in place
Offline RobTJ
« Reply #15 on: June 11, 2017, 06:26:56 PM »
If you are going to drill holes in the bars for these, just take notice that one hole on either side is oblong from the factory.
Ask Tom
