Author Topic: holy death wobble  (Read 1809 times)
holy death wobble
« on: June 13, 2017, 04:21:38 PM »
Had my first taste of death wobble today. man did that suck. Couldn't go over 35mph.
I replaced the steering dampener a few days ago, that's the only thing I can think of that changed. The old Rancho dampener developed a leak so I replaced it with a  Monroe unit.
Think that could have caused it? I've read dampeners will mask DW a little, but this was  huge change.
Offline MattG
  • Probie of the year!
Re: holy death wobble
« Reply #1 on: June 13, 2017, 04:36:14 PM »
Sell it
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #2 on: June 13, 2017, 04:49:34 PM »
some things loose, worn, or broken
dampeners only masked it.
« Reply #3 on: June 13, 2017, 05:22:49 PM »
What steve said something drag link or tie rod
Offline Lambchop
« Reply #4 on: June 13, 2017, 05:34:42 PM »
Id check to see if anything is loose as mentioned but also check alignment
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #5 on: June 13, 2017, 06:13:21 PM »
and Track bar
« Reply #6 on: June 13, 2017, 09:05:17 PM »
Offline Lambchop
« Reply #7 on: June 13, 2017, 09:38:25 PM »
Does it work even better if you use two?
« Reply #8 on: June 13, 2017, 09:47:23 PM »
Loose track bar has been my #1 concern with my TJ...  It's tight now, but if it loosens = death wobble, if it fails = roll over on the highway  :eek: we had this happen to a NEJEEP member many years ago...
« Reply #9 on: June 14, 2017, 05:47:40 AM »
Loose track bar bolt is what was causing it on my Jeep when it happened. Axle side bolt was loose and hole was wallowed out.
« Reply #10 on: June 14, 2017, 07:10:10 AM »
My guess is that the Monroe unit is not as stiff as the old Rancho steering stabilizer and the issue was already there.
My death wobble on the TJ was the lower track bar mount was all hollowed out as others have seen.
« Reply #11 on: June 14, 2017, 09:38:44 AM »
I am guessing it's the lower track bar bolt. In the past I noticed when the steering would get loose it was because that bolt became loose. The through hole is definitely wallowed like 10 mofo's
« Reply #12 on: June 14, 2017, 11:28:52 AM »
Pull the bolt, add a washer, bolt it back up, weld the washer to the mount and call it a day.
« Reply #13 on: June 14, 2017, 11:30:34 AM »
That's the plan, just need time.
Offline Broken99TJ
    • http://www.objectriver.net
« Reply #14 on: June 14, 2017, 12:55:42 PM »
Quote
I am guessing
Exactly
Offline Broken99TJ
« Reply #15 on: June 14, 2017, 12:58:56 PM »
Don't drive it. Any  violent shaking creates more worn parts that have DW memory. Ask me how I know.
« Reply #16 on: June 14, 2017, 01:50:45 PM »
Now I've heard it all! :rotflmao: :rotflmao: :rotflmao:
« Reply #17 on: June 14, 2017, 05:26:27 PM »
 :mad02:
« Reply #18 on: June 14, 2017, 05:29:48 PM »
Track bar was tight. I didn't see anything loose. Maybe tires out of balance
Offline loscann48
« Reply #19 on: June 14, 2017, 06:28:59 PM »
I had an elongated bolt hole in my passenger side track bar mount. I got a plate from teraflex and bolted it in place. Solved my issue with the wobble.
Sent from my VS986 using Tapatalk
G.O.A.T.
Gallagher Outdoor Adventure Team...a fun thing created by my kids and I.
« Reply #20 on: June 15, 2017, 05:01:34 AM »
Cut the trac bar and all that other junk under there off ! Put in your choice of leaf spring and go have a happy day ! CJs Rule !    FjR68
Offline Broken99TJ
« Reply #21 on: June 15, 2017, 02:23:37 PM »
Quote
OK, OK, Once it starts, it spreads. It's like a disease.
Offline XJRV-Maki
  • salt no carry
« Reply #22 on: June 15, 2017, 04:11:14 PM »
I once caught DW just from driving behind the Broken XJ...true story
« Reply #23 on: June 17, 2017, 12:27:07 PM »
So I installed a new Rancho dampener and the day went away. I can still feel a little shimmy around 40 sometimes but it never gets bad and goes away after 45 mph.
« Reply #24 on: June 17, 2017, 01:10:01 PM »
So the dampener is masking the real problem?
