Author Topic: AC question  (Read 481 times)
Offline MattG
  • Probie of the year!
AC question
« on: June 29, 2017, 12:50:32 PM »
The truck AC is dead again.
Last year or year before I replaced the accumulator and orifice tube, and replaced all O rings and hoses, and flushed the system with AC system flush (home job flush)
My AC worked for about a month but then crapped out again. I filled it with UV dye but couldn't find a leak
I pulled the Orifice tube to find a collection of debris on it, not as bad as before but pretty junky.
I took a pic and noticed small metal flakes in it, I'm betting it's the compressor that's shot.
So I was thinking about replacing the compressor and having Matt at Protech flush and recharge it.
Here is a small sample of what I cleaned off the orifice tube.
Re: AC question
« Reply #1 on: June 29, 2017, 01:14:12 PM »
AC is smokin pot
Offline Paul'TheGuest'W
Re: AC question
« Reply #2 on: June 29, 2017, 07:51:10 PM »
Cleaned your orifice did ya?
Offline MassJK
Re: AC question
« Reply #3 on: June 29, 2017, 08:01:32 PM »
thats a lot of nasty looking stuff
Offline MattG
Re: AC question
« Reply #4 on: June 29, 2017, 09:58:53 PM »
Ya I also debated just replacing the condenser and evap core and compressor and calling it a day.
Not sure if it's worth it to flush
Re: AC question
« Reply #5 on: June 30, 2017, 05:05:20 AM »
No debris should be in the system . Also there was no mention on a vacuum pull down before charging . Also on an evacuated , flushed system you would need also to add lubricant for the compressor . Introducing a vacuum is to remove any moister and a good way to test for leaks before recharging. If it wasnt vacuumed , your adding refrigerant to atmosphere in the system and it wont allow enough Freon to be able to stand a load.  Hope this helps .   FjR68
Offline MattG
Re: AC question
« Reply #6 on: June 30, 2017, 06:00:25 AM »
Ya I know, that's why I'm leaning towards replacing it all, and starting fresh.
I pulled a vacuum and added the correct weight oil.
Offline BC Miller
Re: AC question
« Reply #7 on: June 30, 2017, 10:57:58 AM »
Roll down the windows and/or take the top off.  Save a few $$.
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
Re: AC question
« Reply #8 on: June 30, 2017, 11:06:47 AM »
 Yeah Matt!  Take the top off yer truck!  We can do it at a wrenchfest if you need help.
Profile for Team_Oscar
Quote from: Theo Maassen
Offline MattG
Re: AC question
« Reply #9 on: July 03, 2017, 10:45:50 AM »
I ordered all new parts, less than 300 bucks for all the stuff.
Still cheaper than a shop would charge me, and hopefully once I fill it, it will be worry free for a long time
