Author Topic: My weekend plans  (Read 2253 times)
My weekend plans
« on: July 08, 2017, 11:22:56 AM »
Timing chain, water pump, rear main seal and oil pan gasket.
Just getting started draining fluids and removing skid plate.
Sent from my SAMSUNG-SM-G928A using Tapatalk
"Don't lose your Dinosaur"  - Dr. Doback
Offline HankD
Re: My weekend plans
« Reply #1 on: July 08, 2017, 11:35:51 AM »
I'm planning on starting a similar project, as soon as I'm done working. New oil pan, gasket and mail seal.
Offline HankD
« Reply #2 on: July 08, 2017, 11:40:05 AM »
Did that Felpro gasket come with the holder thingies that thread into the block, should make aligning the new pan/gasket a snap.
« Reply #3 on: July 08, 2017, 12:04:23 PM »
Yes, in fact they call them "snap ups" lol. I used them on the opg on my dodge. Super easy.
So my first snag, I get the fan clutch off and it has all sorts of play in it. Actually glad I found it now instead of Moab lol. Add $40 to the job.
Making progress, radiator and fan out. Lets not get into how my Jeep sat with no radiator or grill for weeks during the winter lol.
« Reply #4 on: July 08, 2017, 01:27:37 PM »
Over the winter this job would have been easy access  :rotflmao:
« Reply #5 on: July 08, 2017, 01:30:25 PM »
I said let's not get into that! LoL
Heading to Advance for a new fan clutch and a harmonic balancer puller and installer.
Offline beaker
  • chillin and grillin
« Reply #6 on: July 08, 2017, 07:15:14 PM »
Fan clutch may be your noise.
« Reply #7 on: July 08, 2017, 07:32:07 PM »
good luck!
Offline HankD
« Reply #8 on: July 08, 2017, 08:38:35 PM »
F'd up the new RMS block half, even used the little plastic shoehorn, guess I should have taken the instructions to "deburr" more seriously! lol
Off to Advance in the Morn.
« Reply #9 on: July 08, 2017, 09:02:38 PM »
Did you use dish soap? One of the videos I saw said tge FSM says use dishsoap on the outside and oil on the inside.
Offline HankD
« Reply #10 on: July 08, 2017, 09:33:14 PM »
Instructions on package said to use grease if you're not going to run it right away.
Offline foldsct
« Reply #11 on: July 09, 2017, 09:34:51 AM »
I'm coming to your house to learn how to work on my Jeep!!!!!! :wink:
Online Mr. Easy
« Reply #12 on: July 09, 2017, 09:43:09 AM »
check that the sealing surface on the harmonic balancer isn't grooved to badly. Do you have new balancer seal?
« Reply #13 on: July 09, 2017, 09:45:05 AM »
Do you mean the seal that goes in the timing chain cover? If yes, the timing cover gasket set I bought has a seal.
« Reply #14 on: July 09, 2017, 11:05:32 AM »
Next new discovery... there is a nasty oil leak from the oil pressure sender switch. Fun fun fun and another $45 to the total.
« Reply #15 on: July 09, 2017, 02:20:45 PM »
Been here dude, been there, keep swiging!
« Reply #16 on: July 09, 2017, 02:51:37 PM »
2 more snags. I don't have a proper punch to get the block side of the seal out. Heading to Home Depot.
I can't fit my impact to get at the crank bolt. I rented the removal tool, hopefully I can use that as a crank holder.
« Reply #17 on: July 09, 2017, 03:11:02 PM »
Dull the end of a nail to tap the seal out.
Online Mr. Easy
« Reply #18 on: July 09, 2017, 03:21:14 PM »
yea, that's the seal. I was also saying check the mating surface on the balancer isn't grooved to much or it won't seal.
Offline beaker
« Reply #19 on: July 09, 2017, 04:59:51 PM »
If your talking rear main.  Piece of brass threaded rod will punch it out.
« Reply #20 on: July 09, 2017, 09:53:07 PM »
I didn't get a chance to work on this as much as I wanted. I still have to button up the oil pan.
So, I was able to check the timing chain since I had the oil pan off, and there is only about 1/4" of play. I was hoping it would be worse, because that means my noise is elsewhere. I'm thinking I won't bother changing it. I'm glad I dug into it, because I found the bad fan clutch.
It was in there pretty good. I tried all sorts of things, but couldn't get it to move, and it was starting to mangle.  I ran out and grabbed $9 Harbor Freight punch set. I put the punch in a long socket with am extension and it worked like a charm. The rear main seal is done. Just have to button up the oil pan.
« Reply #21 on: July 09, 2017, 10:11:05 PM »
1/4 inch is a lot of slop in a timing chain - it causes plenty of noise - change it out while you you are this far into the engine  :wink:
« Reply #22 on: July 09, 2017, 10:39:11 PM »
You know it is just the Harmonic balancer left before I get to the timing chain cover... Thanks Frank.
« Reply #23 on: July 10, 2017, 05:57:04 AM »
I have way more slop than that in my timing chain, no noise and I was getting 22 mpg when I was on stock tires... If you are already in there and have the parts, I would most likely still change it out, but I doubt that's the noise.
« Reply #24 on: July 10, 2017, 03:46:01 PM »
Looking good!
