Author Topic: My weekend plans  (Read 2188 times)
Re: My weekend plans
« Reply #25 on: July 11, 2017, 09:19:38 PM »
It looks like more slop than I thought. Hopefully replacing it helps.
Sent from my SAMSUNG-SM-G928A using Tapatalk
« Reply #26 on: July 11, 2017, 09:26:26 PM »
That's a lot of slack  :eek:  do everything you can while you have it torn down to this point  :wink:
« Reply #27 on: July 11, 2017, 09:55:56 PM »
Absolutely. I just have to line up the timing marks, remove the chain and sprockets, then start putting the new parts on.
Side note.... how any different sizes of bolts can they spec for the timing cover?
And the one that also bolts on the alternator bracket was fun to go get to the nut.
« Reply #28 on: July 12, 2017, 04:52:35 AM »
There is no teeth left on the cam sprocket .  You drag racer you . Thats called a HIVO chain . Most stock engines came with them. Upgrade to a roller chain . It looks like a motorcycle chain instead of a bunch of plates pinned together.  There is also a double roller set up for most applications . much stronger and will outlast a HIVO.  FjR68
« Reply #29 on: July 12, 2017, 10:42:52 AM »
I'm surprised the chain didn't skip a tooth or two looking at that slack and worn teeth on the sprocket!  You might want to degree the cam...
« Reply #30 on: July 12, 2017, 05:32:18 PM »
The teeth are still there. It was an illusion because they are tapered. So I'll just go with a standard replacement.
Another question... the balancer/pulley seem fine. Should I just change it since it's a 93 with 145k?
« Reply #31 on: July 12, 2017, 06:22:59 PM »
it wouldn't hurt. this way it's all done and new...
« Reply #32 on: July 12, 2017, 09:12:12 PM »
Thanks Pat, I'll do that.
« Reply #33 on: July 13, 2017, 05:38:21 AM »
Or put the old one back on and when it goes, you're the target of senseless immature jokes. Either way the Club benefits...   :rotflmao:
« Reply #34 on: July 13, 2017, 10:38:07 AM »
That's what you call a win win  :rotflmao:
Offline Prof_Oaks
« Reply #35 on: July 13, 2017, 11:43:01 AM »
As a timing chain engineer, that slop scares the crap out of me....
Offline MassJK
« Reply #36 on: July 13, 2017, 12:07:39 PM »
Lol.
« Reply #37 on: July 13, 2017, 09:53:48 PM »
OK Ian, fear no more! Lol
I only have time to work on thus a little at a time. Only a little progress.
I lined up the timing marks and removed the old chain and sprockets.
Compared them as a check, then installed.
Timing cover has a new seal and ready to go on.
« Reply #38 on: July 13, 2017, 10:13:51 PM »
Good Job!   Do everything while you have it apart that far...
« Reply #39 on: July 14, 2017, 05:26:22 AM »
By looking inside the cover it would show you if the chain was touching the cover making the noise . That looked like a lot of slack Rey.  I bet when you installed the new set you found it was way more critical to be spot on moving both at the same time. The engine will be happy and you will too as your cam was running late stealing low end power . She gonna be like BrandyNew !    FjR68
« Reply #40 on: July 14, 2017, 11:58:05 AM »
It's been hitting the chain guide, which shouldn't be a problem, but the original chain guide is petrified hard as a rock. I didn't realize how bad it was until I compared it to the new one.
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
« Reply #41 on: July 14, 2017, 01:30:32 PM »
That's actually not too bad... I changed the timing chain in my GPZ1100 and it was WAY worse than that...
Course the bikes have tensioners on them too, so they don't slap around...
Profile for Team_Oscar
Quote from: Theo Maassen
« Reply #42 on: July 14, 2017, 04:04:39 PM »
I also got a new harmonic balancer. The original was pretty scored, so I'm glad I did.
Offline MassJK
« Reply #43 on: July 14, 2017, 04:42:48 PM »
Ya that one was chowdered
« Reply #44 on: July 14, 2017, 06:38:52 PM »
Rey bought new parts and installed them. Rey is happy. Be like Rey.
« Reply #45 on: July 14, 2017, 06:48:19 PM »
 :rotflmao: :rotflmao:
« Reply #46 on: July 14, 2017, 11:14:18 PM »
A little more progress. New timing chain,  sprockets, chain guide, balancer, waterpump, thermostat and housing.
All buttoned up nice just before I saw the new thermostat on the bench
The worst one was when I forgot the oil slinger and had to pull the cover.
« Reply #47 on: July 15, 2017, 05:11:18 AM »
Ugh! I've forgotten the t-stat before!
« Reply #48 on: July 15, 2017, 06:17:33 AM »
really hate it when that happens...
Offline crushtheogre
« Reply #49 on: July 15, 2017, 06:35:48 AM »
Crush cuts up a YJ to try to sell tub, engine and transmission, Crush sells a few CJ7 tubs and a frame, Crush does grocery shopping to make wifey happy. Maybe Crush clears the yard a little.......
Before all this Crush goes and buys a 78 Ford F150 that actually runs and drives, I hope(hopefully yard is cleared out to fit it lol)
DONT be like Crush, have a happy wifey....
