Author Topic: My weekend plans  (Read 2187 times)
Re: My weekend plans
« Reply #50 on: July 15, 2017, 06:41:37 AM »
I looked at an E46 Coupe yesterday (didn't buy it), but the lecture I got...
« Reply #51 on: July 15, 2017, 02:20:31 PM »
Might as well have bought it!
« Reply #52 on: July 19, 2017, 05:49:37 AM »
OK, it took me TWO weekends lol. I finally buttoned everything up last night.
The GOOD: It started and seems to run smoother, no more leaks, replaced some parts for general maintenance, and I found 3 issues; fan clutch. badly scored harmonic balancer and oil pressure switch.
The BAD: It didn't fix the noise. The interesting and disappointing thing is that when I first started it, it ran quiet for about 5 minutes, then it started.
Timing Chain and Sprockets
Timing Chain Guide
Front seal (came with the timing cover gasket set)
Fan Clutch
Water Pump
Thermostat
Thermostat housing
Rear Main Seal
Oil Pan gasket
« Reply #53 on: July 19, 2017, 06:48:27 AM »
have you tried pinpointing the noise with a stethoscope?
« Reply #54 on: July 19, 2017, 07:04:32 AM »
I haven't. Probably should have done that first lol. Maybe at Mount Washington, I can have you guys listen to it.
« Reply #55 on: July 19, 2017, 07:08:12 AM »
I had my money the noise was the fan clutch.
It it a rattle, tick or knock?
« Reply #56 on: July 19, 2017, 08:34:04 AM »
incredible usefull considering the simplutuicy and low cost
https://www.harborfreight.com/mechanics-stethoscope-69913.html
« Reply #57 on: July 19, 2017, 11:17:46 AM »
Rey - I have a mechanics stethoscope you can borrow if you want
Offline MassJK
« Reply #58 on: July 19, 2017, 11:31:04 AM »
Might be a dead lifter.
« Reply #59 on: July 19, 2017, 11:34:59 AM »
Sounds like if it went away after a couple min. Throw some Marvel Mystrey oil in the crankcase and see if that cleans it up...
Offline MassJK
« Reply #60 on: July 19, 2017, 11:44:40 AM »
worth a shot
Offline HankD
« Reply #61 on: July 19, 2017, 12:02:21 PM »
That stuff is a great old time remedy, I had a 345 Scout motor I let sit a while, when I got around to starting it again, it spit and sputtered and generally ran like shit. Poured some MMO down the carb a little at a time while it was running, smoked out the whole street, but slowly the engine smoothed out and ran great after that! It unstuck whatever was stuck!
« Reply #62 on: July 19, 2017, 01:02:34 PM »
Use both in oil and gas...
« Reply #63 on: July 19, 2017, 01:15:14 PM »
You can try Seafoam in the crankcase then change the oil.
« Reply #64 on: July 19, 2017, 02:23:54 PM »
A long wooden dowel held to your ear works pretty well for finding ticks and knocks too.
Rislone in the yellow can does a good job too.
« Reply #65 on: July 19, 2017, 04:17:28 PM »
I use a 3' screwdriver. Could it be any of the accessories?
« Reply #66 on: July 19, 2017, 04:18:03 PM »
Everything you did was an improvement so at least there's no loss
« Reply #67 on: July 19, 2017, 06:08:41 PM »
A quarter stick of dynamite will quite the noise too
« Reply #68 on: July 19, 2017, 06:52:16 PM »
You can always bring it to my house. You know what happens to some Jeeps when they come to my house...   :rotflmao:
