Author Topic: Steering Box Questions  (Read 577 times)
« on: July 15, 2017, 05:15:26 PM »
My TJ has an older aftermarket PSC steering box.  I noticed a little slop in the sector shaft when turning full lock (maybe 1/8" of movement tops).  I also think it may be the source of a snapping noise I sometimes get when turning lock to lock...
The casting number on the box is 5687962.  That comes up as a Saginaw part number used on many older trucks.
I checked the PSC website and a new box from them is over $800  :eek:
Are these things rebuild-able?  What makes the PSC box stronger than a factory unit?
The rest of the steering system is a PSC high volume pump and reservoir.
I appreciate any feedback...
Thanks
Offline MassJK
Re: Steering Box Questions
« Reply #1 on: July 15, 2017, 06:10:44 PM »
PSC. Has  a checkered past.
« Reply #2 on: July 16, 2017, 06:28:25 AM »
I happen to prefer PSC over AGR any day !  They are just rebuilt stock and new housings . Yes , every box is rebuild able but a little intimidating if you havent done one. Lots of U-Tube vids on the subject. The biggest difference in the two aftermarket Cos. over stock is the fact the housing are usually machined better and ported to flow better. The pump is usually  a modified stock unit that puts out more PSI. Some of their boxes are ported to add hydro assist steering or total hydro.   If the sector shaft moves any way other than rotate , you can bet the bearing is going and the seal wont like it for very long . There is an adjustment for the sector shaft to get the mesh right (no play) . But that isnt how you fix a moving shaft. Hope this helps.   FjR68
« Reply #3 on: July 16, 2017, 12:21:55 PM »
  I stumbled upon a thread on NAXJA and other Jeep sites that reinforced that notion!
« Reply #4 on: July 17, 2017, 03:20:55 PM »
If it were me, And yes i know Im odd
I would go to the parts store or junk yard, and find a tj steering box for cheap.
Then swap that into your jeep, Take out the psc box and rebuild it. find the bearing numbers, find a saginaw rebuild kit, then swap the rebuilt box into your jeep.
The boxes are very simple, just gotta have a clean work bench and patience
« Reply #5 on: July 17, 2017, 03:41:07 PM »
I agree...... Tom is odd
Only odd is good. I like the idea. And once the newly rebuilt box is installed you'll have a spare one if SHTF
« Reply #6 on: July 17, 2017, 06:48:53 PM »
I spoke with PSC today.  They said the sector shaft bearing probably needs to be replaced.  Said I pay to ship it to them and they will take care of it...
Meanwhile - I'll pick up a stock TJ box and swap it in for the time being
Offline Greenhorn
« Reply #7 on: July 17, 2017, 07:42:31 PM »
Are TJ boxes the same as XJ?
I'm using one out of a 98 Durango (with a V8)
Same length, same mounting footprint, Junkyard cheap.
The body is a larger diameter, meaning the "standoff feet" of the mounting bracket need to be taller.
I just so happen to have a homemade one out of heat treated 718 inconel..LMAO
(NoOOO stressing of any kind allowed there on my unibody)
 -Thomas Jefferson
Online YJScrounge
« Reply #8 on: July 17, 2017, 07:57:26 PM »
I have a YJ box if you want to try it.
« Reply #9 on: July 17, 2017, 09:24:34 PM »
Thanks for the suggestions  :wink:  The 5687962 Saginaw box the PSC box I have is based one that is readily available from Rock Auto for a variety of old 1/2 - 3/4 ton trucks for less than $100...  The Durango box is a bolt on but is pretty much the same as a stock YJ/TJ/XJ as far as piston bore size and uses a sector shaft bushing instead of a bearing...
So the plan is to purchase a cheap 1985 Wagoneer box to install and send the PSC box back to them for an almost free rebuild and swap it back in and keep the wagoneer unit as a trail spare  :wink:
« Reply #10 on: July 18, 2017, 04:28:45 AM »
Wow that's awesome!
« Reply #11 on: July 21, 2017, 06:15:32 AM »
I have a couple CJ (Saginaw)  Boxes on the shelf if interested  ,  4 ears , I only use three.     FjR68
« Reply #12 on: July 21, 2017, 06:44:42 AM »
I love it when a company stands behind their product!
Offline Broken99TJ
    • http://www.objectriver.net
« Reply #13 on: July 21, 2017, 04:28:38 PM »
Quote
I've been known to carry a lot of parts, but never a steering box  :eek:
Offline MassJK
« Reply #14 on: July 21, 2017, 04:46:38 PM »
I've seen 3 box failures in the last few years
« Reply #15 on: July 21, 2017, 05:09:09 PM »
Doc at Fall Crawl and Steve J at Badlands, both were broken sector shafts
Who was the third?
Offline MassJK
« Reply #16 on: July 21, 2017, 05:10:11 PM »
Donny at badlands
Offline MassJK
« Reply #17 on: July 21, 2017, 05:11:01 PM »
That might have been more than a few years
« Reply #18 on: September 30, 2017, 09:17:57 PM »
Sorry to bring this topic back up, but I finally got around to addressing the problem
Friday Morning - Swapped in a 5687962 Saginaw box for a 1985 Jeep Wagoneer (same as the casting on the PSC box), swapped in a new pitman arm and drag link joint.  The system was bled and I went for a test drive - after a mile I had no power steering (felt like the Jeep stalled)...  Couldn't turn the wheels while stopped.  Checked the pressure line - no pressure.  Drove to three parts stores to get a pump to replace the PSC high volume pump.  The plain TJ pump wouldn't fit with the PSC holding reservoir...  So I got a second stock TJ pump with an attached reservoir - now the PSC pressure line with AN fittings won't work  :swear_mad:  no local parts shops had a single stock TJ/XJ pressure line!  Had to drive to NAPA in Norwich to get one today...
So - after all that I have a good Saginaw box, new pitman arm and drag link joint...  And a stock steering pump (somewhat easy to find parts for locally if they fail)
The problem with the PSC pump turns out to be a faulty check valve...
I will address this stuff with PSC, but for a DD and weekend trail rig, having some stock readily available parts seems like the right way to go for now on this (I wheeled for 20 years on stock steering on my old YJ)  The high volume pump will be missed - but probably only needed for hydro assist ram  :wink:
« Reply #19 on: October 01, 2017, 06:43:29 AM »
Oh man talk about a barrel of monkeys! At least you have it square now. Are you still planning on fixing the PSC box and putting it back in?
