Author Topic: synergy ball joints  (Read 208 times)
synergy ball joints
« on: August 01, 2017, 04:23:06 PM »
ok...so greasing lower ball joint/synergy and must have put a pump more than i should have...heard a little pop and now it leaks out of lower end of boot every time i grease...Dont see a rip or anything....worry about it? replace boot?.....They only have about 2-3k on them...thanks guys
Offline Mr. Clean
Re: synergy ball joints
« Reply #1 on: August 01, 2017, 04:29:35 PM »
They've got a lil spring that holds the boot, may have poped the spring or just pushed the boot off, should be able to work it back up without having to take anything apart.
« Reply #2 on: August 01, 2017, 05:26:53 PM »
thanks ill give that a try,,,,
« Reply #3 on: August 01, 2017, 05:28:21 PM »
is that the same for the lowers?
« Reply #4 on: August 01, 2017, 07:11:17 PM »
I believe they both do yes. How old are they? Synergy has a 12 month unlimited warranty.
« Reply #5 on: August 02, 2017, 08:39:59 PM »
they are maybe 4 months old.....boots look intact, must have leaked out of the lower end of the boot where it meets the steel...
