Author Topic: Project Ten Ton  (Read 2468 times)
Project Ten Ton
« on: August 04, 2017, 08:20:51 AM »
Phase 1 of many started last night
Henry Dropped off the front and rear axles for his new jeep build
Chevy Dana 60 low Pinion passenger drop
Detroit locker
Gears
Total rebuild
14 bolt
Detroit
Disc brakes
pinion gaurd
gears
Re: Project Ten Ton
« Reply #1 on: August 04, 2017, 08:22:51 AM »
As you can see the 14 bolt has quite a bit of gravity !
Re: Project Ten Ton
« Reply #2 on: August 04, 2017, 05:23:19 PM »
Nice
Re: Project Ten Ton
« Reply #3 on: August 04, 2017, 05:39:22 PM »
Is this the scramber or the rubi?
Re: Project Ten Ton
« Reply #4 on: August 04, 2017, 06:14:20 PM »
I'm liking the axle setup jig. That will come in handy time and time again.
Online A new level
Re: Project Ten Ton
« Reply #5 on: August 04, 2017, 07:10:48 PM »
Right! X2 no more playing balance the axle on jack stands
Offline Angrytj
  • Luciano
    • My YouTube channel
Re: Project Ten Ton
« Reply #6 on: August 04, 2017, 10:10:07 PM »
Scrambler
2005 Jeep Wrangler Rubicon
Offline Broken99TJ
    • http://www.objectriver.net
Re: Project Ten Ton
« Reply #7 on: August 07, 2017, 08:54:17 AM »
I have a one ton NP241D (Dodge) passenger drop tcase, that I picked up about 10 years ago. I think it has a 23 spine input. It's BIG. I'll sell it for $100.
Re: Project Ten Ton
« Reply #8 on: August 07, 2017, 08:56:00 AM »
pm Todd he may be interested
50willysm38
Re: Project Ten Ton
« Reply #9 on: August 07, 2017, 08:57:26 AM »
does it mount with rivets?
Offline Broken99TJ
Re: Project Ten Ton
« Reply #10 on: August 07, 2017, 09:04:24 AM »
Quote
:question: WTF
Tag says NP241 D1. Flange, no slip yoke. I think is bolts up to a Jeep.
Offline HankD
Re: Project Ten Ton
« Reply #11 on: August 07, 2017, 09:06:09 AM »
Re: Project Ten Ton
« Reply #12 on: August 07, 2017, 09:10:56 AM »
Quote
:question: WTF
Tag says 241 D1. Flange, no slip yoke. I think is bolts up to a Jeep.
 :rotflmao:
Re: Project Ten Ton
« Reply #13 on: August 10, 2017, 07:14:22 PM »
After a weekend away, and some other projects it was time to get back on the axles. The 14 bolt was up first with a set of 5.38 gears. A little work with a carbide burr was needed to make the gears fit in the housing. Some final pattern photos and a pinion gaurd. The backlash is .007
Re: Project Ten Ton
« Reply #14 on: August 10, 2017, 07:15:06 PM »
Up next is a truss and some brake line tabs. Should be good to go in a couple days, then onto the Dana 60
Online MassJK
Re: Project Ten Ton
« Reply #15 on: August 10, 2017, 07:29:46 PM »
oh, Mr fancy pants wants to post pics of the stuff we did before he was aware of what a jeep was.   bla bla bla
:smile:
Re: Project Ten Ton
« Reply #16 on: August 10, 2017, 09:24:56 PM »
that's a phenomenal drive side pattern.
Re: Project Ten Ton
« Reply #17 on: August 10, 2017, 10:42:15 PM »
Meh.
Too much paint. :mrgreen:
Offline HankD
Re: Project Ten Ton
« Reply #18 on: August 11, 2017, 04:46:13 AM »
 :dancingfool:
Re: Project Ten Ton
« Reply #19 on: August 11, 2017, 05:11:52 AM »
Thats one hellava pinion guard ! Who made that ?    FjR68
Re: Project Ten Ton
« Reply #20 on: August 11, 2017, 08:50:31 AM »
oh, Mr fancy pants wants to post pics of the stuff we did before he was born.   bla bla bla
:smile:
FIFY
Re: Project Ten Ton
« Reply #21 on: August 11, 2017, 08:50:56 AM »
I run one on my 9", best $50 I have spent on my JEep
Re: Project Ten Ton
« Reply #22 on: August 12, 2017, 09:18:33 AM »
Let there be truss
Online MassJK
Re: Project Ten Ton
« Reply #23 on: August 12, 2017, 10:07:15 AM »
It's more of a bridge than a truss :mad02:
Re: Project Ten Ton
« Reply #24 on: August 12, 2017, 10:21:10 AM »
Sexy
So Henry what is the end goal in tire size? 40's?
"Don't lose your Dinosaur"  - Dr. Doback
