Author Topic: Project Ten Ton  (Read 2439 times)
Offline HankD
Re: Project Ten Ton
« Reply #25 on: August 12, 2017, 11:48:20 AM »
39" reds!
Offline Broken99TJ
    • http://www.objectriver.net
Re: Project Ten Ton
« Reply #26 on: August 15, 2017, 12:27:08 PM »
That truss weights ten tons.
Re: Project Ten Ton
« Reply #27 on: August 20, 2017, 08:55:52 PM »
So with the 14 bolt wrapped up it was time to tackle the Dana 60 front. The tear down took longer than anticipated. Everything that could be rusted in place was. It took Henry and I about an hour to remove the high steer arm.
After getting the housing torn dow it was time to set up the gears, and new Detroit.
Offline HankD
Re: Project Ten Ton
« Reply #28 on: September 19, 2017, 07:45:14 AM »
Tom stopped by to help me rotate my tires........
Sent from my SAMSUNG-SM-G900A using Tapatalk
Re: Project Ten Ton
« Reply #29 on: September 21, 2017, 07:54:09 AM »
Re: Project Ten Ton
« Reply #30 on: September 21, 2017, 07:59:22 AM »
no rest for the weary
Re: Project Ten Ton
« Reply #31 on: September 21, 2017, 08:02:34 AM »
Re: Project Ten Ton
« Reply #32 on: September 21, 2017, 08:02:54 AM »
That thing is going to be cool as hell!!
Re: Project Ten Ton
« Reply #33 on: September 21, 2017, 08:04:55 AM »
A little update,
Monday Henry and I pulled the body off the scrambler and assessed the frame. there are a couple patches here and there but overall in good condition.
Last Night I picked up the frame, all the tubing, some shiny green parts and the tires. Henry already marked out where the axle need to go. after unloading the frame, it was setup at ride height and the axles slid into there final home.
This weekends plan is to work on the rear link numbers ( most time consuming part) and start cutting tube
Online RedJeepster1
Re: Project Ten Ton
« Reply #34 on: September 21, 2017, 08:19:15 AM »
Holy rear driveshaft, that thing is long! This thing is gonna be sweet.
Re: Project Ten Ton
« Reply #35 on: September 21, 2017, 11:56:59 AM »
R U sure uou know what yer doing???   :eek:  :razz:  :rotflmao:
Re: Project Ten Ton
« Reply #36 on: September 21, 2017, 11:58:09 AM »
Not a friggan clue
Re: Project Ten Ton
« Reply #37 on: September 21, 2017, 12:40:45 PM »
Re: Project Ten Ton
« Reply #38 on: September 21, 2017, 12:44:00 PM »
Not a friggan clue
Fake it till you make it!
LOL If you cant engineer it, over build it
Re: Project Ten Ton
« Reply #39 on: September 21, 2017, 12:49:16 PM »
Re: Project Ten Ton
« Reply #40 on: September 21, 2017, 02:40:47 PM »
Amazing what you csn do with a squirt gun...
Re: Project Ten Ton
« Reply #41 on: September 21, 2017, 06:28:52 PM »
Looked it up cuz I was curious
CJ8 wheelbase 103.5"
JKU wheelbase 116"
Re: Project Ten Ton
« Reply #42 on: September 21, 2017, 09:09:25 PM »
XJ Wheelbase is almost perfect at 101.4", the KJ get's a little bit over at 104.2"  So the CJ8 should be just right  :wink:
Re: Project Ten Ton
« Reply #43 on: September 22, 2017, 04:41:37 AM »
My JK will eventually be 101.4"  :cool:
Re: Project Ten Ton
« Reply #44 on: September 25, 2017, 07:38:56 AM »
Online RedJeepster1
Re: Project Ten Ton
« Reply #45 on: September 25, 2017, 07:45:42 AM »
Lookin good Tom! How are you attaching the base of the shock hoop to the frame? Just notch it and weld to a 2" or so piece of tube welded perpendicular to the frame?
Re: Project Ten Ton
« Reply #46 on: September 25, 2017, 07:46:57 AM »
This weekend was very productive, becca was away visiting her father. I spent as much time as I could in the garage.
- valve cover gaskets on my dads camper van
- crank position sensor on the jeep
-oil change on the ranger
-rebuilt the steering on my truck
- re wired the 3 phase for the lathe
-cleaned the garage / reorganized
- made a mess working on henrys jeep
Friday night was a late night, and finalized all the numbers. Saturday morning I began making the links up and tacking on the mounts for the lowers. because I dont have the motor to transfer case yet the front links are in space.
The upper links then fell into place. Lastly it was time to bend up the ORI hoops
so far so good, this weeks project is the front
Re: Project Ten Ton
« Reply #47 on: September 25, 2017, 07:49:44 AM »
Im not entirely sure yet. I kind of want to run the perpendicular tube through the frame. I dont trust 2 welds to hold up one corner of the frame
Re: Project Ten Ton
« Reply #48 on: September 25, 2017, 03:25:57 PM »
That's going to be a full on roller before you know it!
Re: Project Ten Ton
« Reply #49 on: September 25, 2017, 03:36:27 PM »
Thats the plan
