Author Topic: Project Ten Ton  (Read 2438 times)
Re: Project Ten Ton
« Reply #50 on: September 25, 2017, 03:56:13 PM »
Tom, I need to borrow you for two weeks once my shop is finished! :mrgreen:
Re: Project Ten Ton
« Reply #51 on: September 25, 2017, 04:49:36 PM »
What are we building ?
Offline MassJK
Re: Project Ten Ton
« Reply #52 on: September 25, 2017, 04:52:51 PM »
walking targets and a gong rack mabe a dueling tree too
Re: Project Ten Ton
« Reply #53 on: September 25, 2017, 06:56:06 PM »
Thinking cage, but that would work too. :rotflmao:
Re: Project Ten Ton
« Reply #54 on: September 25, 2017, 07:50:29 PM »
I'll drive down and bring my welder
Re: Project Ten Ton
« Reply #55 on: September 25, 2017, 07:59:34 PM »
Kid has the Juice. Gotta give him that.
Re: Project Ten Ton
« Reply #56 on: September 25, 2017, 08:19:37 PM »
I stopped by a couple times this weekend and Tom explained the math, figuring, and gozintas that are involved.
Pretty simple once you get all the numbers dialed in, but you can really fawk it up if you change one thing just a little bit.
Re: Project Ten Ton
« Reply #57 on: September 25, 2017, 08:51:25 PM »
"gozintas"  :rotflmao:
Re: Project Ten Ton
« Reply #58 on: October 13, 2017, 08:06:52 AM »
Due to traveling the last few weeks, progress has been slow !
Finally unpacked my tools and began working on the jeep last night. about a week ago the motor was dropped off along with a ton of other parts. For the most part it was purely supported by the engine hoist. Last night Becca went to bed early, so i began working on the rear link cross-member. the cross-member will be removable, to make transfer case removal possible.
The plan for this weekend is,
- fully mount cross-member
- mount lower links
- Mount rear ori hoops
-Start trans cross-member
Re: Project Ten Ton
« Reply #59 on: October 13, 2017, 08:57:57 AM »
That thing is going to be a beast!
Online RedJeepster1
Re: Project Ten Ton
« Reply #60 on: October 13, 2017, 09:06:35 AM »
Going to have a separate cross member to hold the transmission mount and run a flat skid between them? And I assume you checked, but those front lower links don't hit the body mount at full bump, right? Looks like this thing is coming together really nicely. Well done.
Re: Project Ten Ton
« Reply #61 on: October 13, 2017, 03:54:46 PM »
MMMM Atlas.....
Re: Project Ten Ton
« Reply #62 on: October 30, 2017, 02:54:40 PM »
Re: Project Ten Ton
« Reply #63 on: October 30, 2017, 03:02:31 PM »
Alright, it has been a while since an update. progress has slowed a bit due to parts and other events.
from the top down, the frame will drilled and sleeved for the cross member bolts. the bolts used are 1/2 inch.
With the cross member in place the final ori tower braces were tacked into place and then fully welded.
The trans crossmember was bent up and attached to the frame using tabs and builder bushings. the bushings are mounted in line with the frame so they flex at the same rate as the motor mounts.
Moving forward I tackled the front hoops, which seemed to get in the way  of everything. the solution was a thinner hoop than the rear, the hoop is angled toward the rear at a 15 degree angle
The hoops were notched and then welded into place, a matching set of lower bungs were created to match the rear. Maintaining style points is key.
next up was the exhaust, after 3 revisions we finally have a winner, what a pain in the arse. the frames are far too narrow for easy packaging of a V8
Re: Project Ten Ton
« Reply #64 on: October 30, 2017, 03:11:57 PM »
That is unreal Tom. Awesome work. So will this be on the trail in 2018?
Re: Project Ten Ton
« Reply #65 on: October 30, 2017, 03:15:08 PM »
I would hope so, Im hoping to wrap up my portion by thanksgiving. We shall see what happens
Offline RobTJ
Re: Project Ten Ton
« Reply #66 on: October 30, 2017, 03:25:37 PM »
I see a magazine photo shoot in this rigs future.
Re: Project Ten Ton
« Reply #67 on: October 30, 2017, 03:26:49 PM »
And a weigh station
Offline HankD
Re: Project Ten Ton
« Reply #68 on: October 30, 2017, 05:21:14 PM »
If the owner does his part, many parts!
Re: Project Ten Ton
« Reply #69 on: October 30, 2017, 06:29:06 PM »
I got excited thinking that was a turbo up pipe till I realized the y pipe is in front. Definitely looks like a PITA
Re: Project Ten Ton
« Reply #70 on: October 30, 2017, 06:51:55 PM »
Impressive.
Re: Project Ten Ton
« Reply #71 on: October 30, 2017, 08:13:38 PM »
I hope Hank appreciates you!
Online RedJeepster1
Re: Project Ten Ton
« Reply #72 on: October 31, 2017, 05:56:17 AM »
Digging that exhaust, definitely tight with that drive shaft right there!
Re: Project Ten Ton
« Reply #73 on: October 31, 2017, 02:55:07 PM »
Does you bender do exhaust tubing and flairing?
Re: Project Ten Ton
« Reply #74 on: October 31, 2017, 03:00:49 PM »
Unfortunately it does not, henry purchased one of those kits with a million bends. it was all just cut and make fit, and make sure you cut on the right side with the flare
