Author Topic: Exhaust  (Read 483 times)
Offline Ryean78
Exhaust
« on: August 10, 2017, 09:00:46 AM »
I installed new exhaust system Flowmaster American Thunder on a 2015 JKU. I hate the sound it is producing! That is the negative part. The bonus part is it gets rid of the big exhaust can on the rear. Tucks everything up and away from getting crushed like the existing. My question is has anyone dealt with this issue? If you have what did you do to help quiet it down. Could I install a small resonator after the muffler? Would that quiet it down? If it does work what brand should I be looking for? Maybe my best bet would be to go to a muffler shop and let them suggest something?
Online Right Wing Curmudgeon!!!
Re: Exhaust
« Reply #1 on: August 10, 2017, 09:14:11 AM »
Re: Exhaust
« Reply #2 on: August 10, 2017, 09:20:10 AM »
flowmaster = dronemaster
Offline Ryean78
Re: Exhaust
« Reply #3 on: August 10, 2017, 09:35:01 AM »
I watched numerous videos of this exhaust and others. Read reviews. More people than not liked it. I am frustrated with it. I'm hoping for an option I haven't thought of. I'm kinda stuck at the moment the existing is crushed. That was the reason for replacement.
Offline Angrytj
  • Luciano
    • My YouTube channel
Re: Exhaust
« Reply #4 on: August 10, 2017, 09:36:49 AM »
can you post a pic of how the exhaust is routed? I may have an idea for you
2005 Jeep Wrangler Rubicon, 35s, 5in rear stretch, Poison Spyder hiline defender front fenders and rear armor, Rokmen Sliders, custom hiline hood, Synergy front half and custom rear half roll cage, Mastercraft seats, 4pt harness, TJ rubi 44 axles, ARBs, 488 gears, chromo shafts, truss front and rear, front axle is sleeved, tie rod flip, PSC hydro assist steering box and ram, Vanco big brake kit, Raceline beadlocks and other little things.
Online RobTJ
Re: Exhaust
« Reply #5 on: August 10, 2017, 09:38:59 AM »
You get use to it after awhile.
The Spintech muffler that Clayton put on mine, was almost unbearable.    And since it has been moved forward,  I'm basically sitting on top of it.
Offline Ryean78
Re: Exhaust
« Reply #6 on: August 10, 2017, 09:40:37 AM »
Offline loscann48
Re: Exhaust
« Reply #7 on: August 10, 2017, 09:41:29 AM »
I put a dynomax super turbo on my 2010. I just bought the muffler for $45 on amazon. I cut my exhaust just behind the drivers seat, clamped in the dynomax, and clamped on the factory turn down just before the axle.
Sent from my VS986 using Tapatalk
G.O.A.T.
Gallagher Outdoor Adventure Team...a fun thing created by my kids and I.
Offline Ryean78
Re: Exhaust
« Reply #8 on: August 10, 2017, 10:15:52 AM »
2010 had the 3.8 motor from what I've been told the two sound completely different.
Offline Greenhorn
Re: Exhaust
« Reply #9 on: August 10, 2017, 10:37:04 AM »
 :mrgreen:
 -Thomas Jefferson
Offline MassJK
Re: Exhaust
« Reply #10 on: August 10, 2017, 10:53:37 AM »
Turn the muffler around
Offline Angrytj
  • Luciano
Re: Exhaust
« Reply #11 on: August 10, 2017, 11:08:40 AM »
Is it touching your floor?
Offline Ryean78
Re: Exhaust
« Reply #12 on: August 10, 2017, 11:12:53 AM »
Excuse my ignorance, but would that actually help or change anything?
Offline Ryean78
Re: Exhaust
« Reply #13 on: August 10, 2017, 11:13:22 AM »
The muffler sits about a 1/2" from the floor.
Online JeepinMaxx
Re: Exhaust
« Reply #14 on: August 10, 2017, 11:32:58 AM »
Do you hate the sound outside the vehicle or the resonance sound in the cabin?  If its the inside sound - try some Thermo Tec heat / sound shield on the bottom of the floor above the exhaust
Offline MassJK
Re: Exhaust
« Reply #15 on: August 10, 2017, 11:49:03 AM »
depending on how it is chambered it may.  That looks like a hushpower with the cone inside so it may not help
Offline Ryean78
Re: Exhaust
« Reply #16 on: August 10, 2017, 12:54:52 PM »
Really it's both. The drone is bad anything more than 1/4 throttle it sounds like a Honda Civic. When I keep the RPMs down it's not bad.
Re: Exhaust
« Reply #17 on: August 10, 2017, 03:50:22 PM »
is there room for a different muffler ? how much space do you have to work with ?
Offline Angrytj
  • Luciano
Re: Exhaust
« Reply #18 on: August 10, 2017, 04:17:40 PM »
If you hate the sound of it even when your outside of the jeep then you just need a new muffler but if you want to try and reduce the noise from inside there are options.
Offline Ryean78
Re: Exhaust
« Reply #19 on: August 11, 2017, 06:45:59 AM »
I had my wife drive the jeep last night so I could listened to it go down the road. I really think its the drone inside the cab. Outside the Jeep sounds pretty good a little loud. I have found that there is one spot in the RPM range where the exhaust is extremely raspy. I have also read that there is a break in period for exhaust and that it will quiet down the longer it is on the Jeep. Not sure how true that is. I guess for now I am going to keep it on. Worst case if it does not quiet down, I can start changing mufflers.
