Author Topic: TEN Factory chromoly axle group buy  (Read 1839 times)
« on: August 11, 2017, 06:59:33 AM »
Eric from Offroad Elements is gauging interest on chromoly rear axle shaft group buy. He'd be able to get a set for a 44 down to $375 (30 spline) to $395 (Rubi) shipped (everything pressed and ready to install). Let me know if you need a set for a different axle. If anyone is interested I'll pass it on and if it goes through I'll post a link.
** updated post with easier list to read. Prices are shipped**
TJ/XJ D30 fronts $469
TJ Rubi and Non-Rubi D44 Rears $252
TJ Non-Rubi D35 backordered, $252
XJ 8.25 $159 for 97-01, $219 for 91-96  just need bearings/seals
JK rear Non-Rubi $375, Rubi $395 with everything pressed
www.offroadelements.com/ten-factory-dana-44-rear-chromoly-axle-kit-30-spline-pressed-wrangler-jk-2007/
Offline Ryean78
Re: TEN Factory chromoly axle group buy
« Reply #1 on: August 11, 2017, 07:03:40 AM »
I'm interested after doing all the work to my front the rear is deff in need of beefing up.
« Reply #2 on: August 11, 2017, 07:31:27 AM »
I'd be interested in at least getting a price for a 29 spline Chrysler 8.25 for a 2000 XJ if they make them. The stock shafts are pretty beefy but if they are cheap enough it would be good insurance.
Offline NickMaida
« Reply #3 on: August 11, 2017, 08:01:48 AM »
Always been interested in TJ Dana 30 shafts. I think some others would be interested as well.
'97 TJ 4.0 - 35s
« Reply #4 on: August 11, 2017, 08:39:54 AM »
Yes, I would be interested in TJ D30 cromoly shafts
« Reply #5 on: August 11, 2017, 08:45:21 AM »
If you were to get chromoly shafts, I would be interested in your old modified shafts that accept the full circle snap rings, unless you decided to keep them as spares.
« Reply #6 on: August 11, 2017, 07:21:07 PM »
Sounds good. I'll have prices on Monday.
Online Right Wing Curmudgeon!!!
« Reply #7 on: August 11, 2017, 09:58:13 PM »
Get me a price on TJ rubi axles. :mrgreen:
Offline HankD
« Reply #8 on: August 12, 2017, 05:18:35 AM »
83 Chevy Dana 60 front set, 35 spline outer upgrade.
« Reply #9 on: August 12, 2017, 08:22:23 AM »
I'll add those to the list
Offline XtraChrisP
  • Yup
« Reply #10 on: August 12, 2017, 02:46:49 PM »
05 Rubicon axles prices for me too please
« Reply #11 on: August 15, 2017, 06:34:15 PM »
Ok prices so far. Eric spaced on sending me info yesterday lol
8.25 is $159 for 97-01, $219 for 91-96... Shipped both sides, just need bearings/seals
« Reply #12 on: August 15, 2017, 06:37:24 PM »
TJ Rubi and Non-Rubi D44 Rears $252 Shipped
TJ Non-Rubi D35 backordered, $252 Shipped
« Reply #13 on: August 15, 2017, 06:38:04 PM »
D60 w/ 35sp both ends,  Ten Factory $819 Shipped (4 weeks out currently)
« Reply #14 on: August 15, 2017, 06:39:54 PM »
Let me know if I missed anything or if your interested. Like I said it's currently a feeler but if I can get a ruff count of who's in hopefully it will happen. Thank you
Online JeepinMaxx
« Reply #15 on: August 15, 2017, 06:46:37 PM »
Did I miss the pricing for the TJ D30 front axles or did you mean D30 instead of the D35 you listed above?
« Reply #16 on: August 15, 2017, 06:57:01 PM »
That's probably 35 rear. Sorry don't know my TJs as well as I should and totally missed that. Stand by to stand by.
« Reply #17 on: August 15, 2017, 06:58:31 PM »
You can count me in for one set of late model rear 8.25 shafts. I'm about to regear that axle so I might as well change the shafts out while I am in there.
Offline Prof_Oaks
« Reply #18 on: August 15, 2017, 07:04:42 PM »
I could be in on the late model 8.25s as well.  Any font axle stuff or is this just rear axle?
Offline Prof_Oaks
« Reply #19 on: August 15, 2017, 07:13:15 PM »
If we are also talking front axle I may be interested in 01 xj Dana30 shafts
« Reply #20 on: August 15, 2017, 07:56:50 PM »
XJ 30 fronts roger
« Reply #21 on: August 15, 2017, 08:00:18 PM »
XJ 30 fronts roger
I believe they are the same as the TJ d30 shafts.
« Reply #22 on: August 15, 2017, 08:01:47 PM »
XJ 30 fronts roger
Kinda figured but I'll make sure thank you
« Reply #23 on: August 16, 2017, 06:15:41 AM »
I am running a hp XJ 30 in my tj, can confirm shafts are the same.
« Reply #24 on: August 16, 2017, 06:34:18 AM »
Perfect thank you
