Author Topic: TEN Factory chromoly axle group buy  (Read 1995 times)
Offline Broken99TJ
    • http://www.objectriver.net
Re: TEN Factory chromoly axle group buy
« Reply #25 on: August 17, 2017, 07:48:18 AM »
No,No,No, you guys don't need Chromoly anything. With the exception of Cory, your not going to break anything. Stop reading the magazines.
« Reply #26 on: August 17, 2017, 08:31:13 AM »
What ?
im so confused, When did factory shafts get stronger.
Normal tire sizes have increased, however stock axle shaft size has not...
Times have changed
« Reply #27 on: August 17, 2017, 08:37:47 AM »
nothing a few well placed rivets can't fix.  :rolleyes:
« Reply #28 on: August 17, 2017, 10:36:39 AM »
This coming from a guy who's nickname is Broken...... :rotflmao:
« Reply #29 on: August 17, 2017, 11:24:37 AM »
Always been interested in TJ Dana 30 shafts. I think some others would be interested as well.
Yes, I would be interested in TJ D30 cromoly shafts
Get me a price on TJ rubi axles. :mrgreen:
05 Rubicon axles prices for me too please
TJ Rubi and Non-Rubi D44 Rears $252 Shipped
TJ Non-Rubi D35 backordered, $252 Shipped
Did I miss the pricing for the TJ D30 front axles or did you mean D30 instead of the D35 you listed above?
TJ/XJ D30 fronts $469 shipped.
Offline Ryean78
« Reply #30 on: August 17, 2017, 12:53:07 PM »
I'm in let me know where I need to go to buy rear Jk axles.
One question might be stupid, but I do not know. Does the spline count need to match the front? Learning on the fly here!
Online RedJeepster1
« Reply #31 on: August 17, 2017, 01:00:45 PM »
Spline count on the axle shafts just has to match the spline count on the carrier for that axle. Rear and front are independent of each other. For example my front dana 30 is 27 spline and my rear Chrysler 8.25 is 29 spline.
Offline Ryean78
« Reply #32 on: August 17, 2017, 01:03:34 PM »
I am glad I asked! Thank you Jeremy!
So I went with 488 gears stock JK Dana 40 in the rear would they had to change the carrier? I am pretty sure they changed the carrier actually. I will have to look at existing parts tonight.
« Reply #33 on: August 17, 2017, 01:11:54 PM »
stock spline count axles are fine, going to larger spline count is stronger but you will have to buy a new carrier shafts and wheel bearings in some situations
stick with cromo stock size shafts
You wont break them
Offline Miley Cyrus
« Reply #34 on: August 17, 2017, 03:20:51 PM »
I might get a set of non rubi 44
Offline Broken99TJ
« Reply #35 on: August 18, 2017, 07:22:53 AM »
Quote
OK, maybe I've broken a few axles. I probably should have counted them.  :eek: But, in my defense almost all of them were 260 u-joints. Dana 30's come stock with 44 u-joints.
Here's a suggestion, don't buy chromemoly until you have broken an axle. If you wollow the short-side axle ears, just JB-Weld the u-joint in.  :eek:
Quote
When was it, that 35" tires got bigger  :mrgreen:
« Reply #36 on: August 18, 2017, 08:55:00 AM »
Really?  Wait until you break and axle?  Are you kidding me!? :eek:
It's better to swap them out with Chromos then use the stockers as spare for the trail.
Yeah, I just love wheeling with people who "Don't Care" about breaking on the trail...... :rolleyes:
Offline Broken99TJ
« Reply #37 on: August 18, 2017, 09:14:57 AM »
Quote
Breaking, is when the social and engineering part of Jeeping happens.  :rotflmao:
Offline XJRV-Maki
  • salt no carry
« Reply #38 on: August 18, 2017, 09:43:28 AM »
$159 for a pair of 29 spline 8.25's is almost a no-brainer. I've seen stock 29 spline shafts sell for $100.
I'm running 27 spline now with Detours secret locker, but if I were thinking about a full case locker I'd definitely buy those instead of sourcing a stock pair.
But I never complained all the times Broken spit out a ujoint, those were simple fixes and there always was a lot of camaraderie (and ball busting from Earle). Fixing Jeeps in the mud and rocks were good memories, things seemed less complicated then.
Offline MassJK
« Reply #39 on: August 18, 2017, 09:58:08 AM »
It's all fun and games till you snap a leaf pack in half
Offline Broken99TJ
« Reply #40 on: August 18, 2017, 10:39:03 AM »
Quote
Yea, That was bad and loud. :eek: Hahaha. Didn't have a spare one of those.  :eek:
Online RedJeepster1
« Reply #41 on: August 18, 2017, 11:07:57 AM »
That sounds like it would be a hell of a story.
Offline MassJK
« Reply #42 on: August 18, 2017, 11:18:51 AM »
You have no idea.  Pretty sure he broke the front end 300' later
« Reply #43 on: August 20, 2017, 07:15:26 AM »
Just a word on stronger axle shafts , worth mentioning .  Actually its a question .  If you break an axle (D-30) U-joint , you may take out the ears also . If you make the axle shaft so very strong it wont break first , Take a guess whats next in line ?????????????????  Just saying folks ,  The differential cost way more money than a shaft.  JKs have weak axle housings , spend yer cash on fixin that. Just my opinion and that dont count fer Chit !     FjR68
« Reply #44 on: August 20, 2017, 07:34:33 AM »
Trussing JK axles is definitely a good idea
Online RedJeepster1
« Reply #45 on: August 31, 2017, 11:57:18 AM »
Is this still in the works? Should be pulling my 8.25 this weekend. Would love to put shafts in it when I have it apart to regear.
« Reply #46 on: August 31, 2017, 05:48:47 PM »
Sh*t sorry so much on my plate this got mentally pushed aside. Standby
Offline Johny Pornstash
« Reply #47 on: August 31, 2017, 08:05:34 PM »
Always have the easiest and cheapest part to replace be the weakest link... U joints and axle ears...
Online RedJeepster1
« Reply #48 on: September 01, 2017, 05:45:23 AM »
Not to go off topic, but anyone ever consider cryo treating their gears? Supposed to make a substantial difference in strength, most likely bringing the breaking point back to the shafts, even with chromoly's.
http://www.fourwheeler.com/how-to/transmission-drivetrain/129-0705-cryogenic-gear-treatment/
« Reply #49 on: September 01, 2017, 06:02:31 AM »
I prefer to overbuild and not break
