Author Topic: TEN Factory chromoly axle group buy  (Read 1841 times)
Re: TEN Factory chromoly axle group buy
« Reply #75 on: October 25, 2017, 09:38:37 AM »
Not a huge fan of those axle seals, if anything they trap crap in the axle tube. as the knuckles turn it forces the longer side of the axle to pivot in the tube. The seals are compressed and crap goes in the tube. every time ive pulled the axle shafts, and seals there was water and grime in there. atleast with the tubes open the stuff is able to work its way out.
After sleeving a dana 30, it works way better than adding a truss. the only downside is it now making the weakest point the axle housing.
by sleeving the tubes it also decreases the amount of stuff that can build up in the tubes. If you install tube sleeves you cannot run the seals
« Reply #76 on: October 25, 2017, 09:57:47 AM »
I have those, I agree they just trap crap in.  I'm taking mine off the next time I pull my axles. :swear_mad:
« Reply #77 on: October 25, 2017, 10:40:04 AM »
Good to know. I don’t have the plastic dust guards anymore and was considering getting some of these seals. Guess I’ll leave it alone though.
Online A new level
« Reply #78 on: October 25, 2017, 10:50:12 AM »
This info helps make up my mind what to do with my axles. Currently I have seals. Didn’t sleeve yet because I couldn’t figure out what axles size to go with. Had contemplated 35 spline. Also thought about doing full float kit. I really like all of the Rock Krawler stuff but there’s no way to compare to 60s. Current plan is to stick with the 32 spline, sleeve and truss 44s till it’s time for 60s.
Offline Broken99TJ
    • http://www.objectriver.net
« Reply #79 on: October 26, 2017, 11:57:46 AM »
If you do heavy mud, not mud puddles, you need those axles seals. I've had so much sand in the tube that it lifted the axle up and leaked at the carrier seal. Had to wet vac the axle tube out.
« Reply #80 on: October 26, 2017, 12:09:46 PM »
And this is why I avoid mud !
