Author Topic: WTB 8.8 or Dana 44 set up for TJ  (Read 252 times)
Offline mfw1fan24
« on: August 20, 2017, 05:12:04 PM »
Looking for a good used 4.10,4.11 rear for a TJ
Offline Paul'TheGuest'W
Re: WTB 8.8 or Dana 44 set up for TJ
« Reply #1 on: August 25, 2017, 08:43:17 AM »
I have one.  4.10's limited slip, brackets for tj already welded on.  It's physically in Westminster Vt, or Keene Nh, depending on when you can pickup.  It's 91-94 explorer so it's drum brakes.  Needs wheel cylinders and lines made.  I have the companion flange for the stock driveshaft as well.
« Reply #2 on: August 28, 2017, 06:18:29 AM »
96/2002 Explorer axle 8.8 will have 31 spline , most with 4.10s , most with limited slip and disk brake. Airtec has a bracket/truss for the TJ that is easy and perfect alignment but its weld on . Ive done several with this kit and its awesome.   FjR68
Offline crushtheogre
« Reply #3 on: October 24, 2017, 05:16:22 AM »
If you're still looking I have a TJ factory rear Dana 44, 3.73 gears, good shape, has all parking brake cables and brackets still on it, $650
