Author Topic: Project " Tap Dat Box"  (Read 285 times)
« on: August 20, 2017, 08:36:54 PM »
Another jeep was brought over this weekend, Damon for a long while has had issues with the Mercedes style steering box. This box was used in any tj built after 2003. The steering box is a dual rate box, which is weaker than the Saginaw counterpart.
The soloution, replace the dual rate box with a standard jeep steering box. Drill and tap the new box for hydro assist, then mount the ram.
After pulling the steering and the box out of the way it was time to figure out the mounting location. The bolt pattern is slightly different from the Saginaw box. The forward most frame sleeve needs to be relocated.
Using a 1 inch hole saw the sleeve can be carefully cut out and reused.
With the sleeve removed a carbide burr will be used to open up the hole
Re: Project " Tap Dat Box"
« Reply #1 on: August 20, 2017, 08:47:28 PM »
I like the double nut future!
Putting in a Durango box?
« Reply #2 on: August 21, 2017, 03:15:40 PM »
Nope using a standard tj box, the durango box does not always work well when drilled for hydro assist
« Reply #3 on: August 22, 2017, 11:05:48 AM »
The Durango box is the only one I have blown up.  I went back to a stock TJ as well.
Keep your measurements, I'm sure I will be doing one soon.
