Author Topic: Door Handle Workings  (Read 209 times)
Offline JeepMM2
« on: September 06, 2017, 07:23:01 PM »
How is the door handle on the steel doors held in place? I started having a problem opening the driver's side about two months ago. Now it appears the handle is coming loose.
"I'M THE 82nd AIRBORNE, AND THIS IS AS FAR AS THE BASTARDS ARE GOING."
PFC Martin, 325th Glider Infantry Regiment  Dec. 23, 1944
Online JeepinMaxx
Re: Door Handle Workings
« Reply #1 on: September 06, 2017, 09:30:47 PM »
Mark - full steel TJ doors?  I had problems with mine too - I think there are some bushings that wear to make them loose.  I bought brand new door handle assemblies for the driver side and passenger side last year, but my hands are too big to get in between the door panels!  So I gave up (I may cut an access hole this fall)  So I just sprayed a bunch of Kroil and made it through last winter
Offline XtraChrisP
  • Yup
« Reply #2 on: September 07, 2017, 04:45:57 AM »
If I remember correctly if you can get your hands back there, I believe there are a few "shins" that wedge the handle in place and keep it there. If you can manage to pry them out after getting the rest of the door apart then you should be able to swap em
« Reply #3 on: September 07, 2017, 05:37:57 AM »
does this help?
Offline JeepMM2
« Reply #4 on: September 07, 2017, 07:26:49 PM »
