Author Topic: Build questions - Groundhog Resurrection continues...  (Read 131 times)
Offline Groundhog
  • "Stand Up, Speak Out & Shoot Back!"
    • http://www.aardvarkaudiodj.com
« on: September 20, 2017, 08:19:04 PM »
Okay, it's time to open up that can of worms where I ask for recommendations!! LOL
I just got the 4.0 back from the engine builder and figured I'd run these items by this trusted crew.
So... what are the recommendations for:
Fuel injectors - I'm most likely sticking with 19 pound injectors, but there are many forum chats about different types of injectors - or should I just go OEM?
Distributor - Looking for  pretty much stock, but is there a preferred brand or type you all gravitate to?
Exhaust manifold gasket -
Keep in mind this is only a mild build - mild Comp Cam, Melling HV oil pump and Moroso 7.25 qt.off-road oil pan, Melling timing set. There will be no cold air kit or fancy exhaust sizes - I've learned my lesson there. LOL
"There is a deep laid plot against your civil & religious liberties. Your golden days are at an end. My heart bleeds for you, America."
- George Whitfield, 1714-1770
Re: Build questions - Groundhog Resurrection continues...
« Reply #1 on: September 20, 2017, 10:16:44 PM »
Nice Job!
Back in 2004 when I did my 4.0 swap in my YJ I went with Ford Mustang 5.0L Bosch 4 hole 24 pound injectors with a Borla header and cold air intake (plus a Mopar Performance ECU)  because of the ECU I needed to use 91 octane...   Those injectors plus the intake and header made great power like a dirt bike getting "on the pipe" at around 2500 RPM!  It would smoke 33's in 2nd gear  :mrgreen:
« Reply #2 on: September 21, 2017, 04:53:56 AM »
If you don't want as big of injectors, dodge neon injectors are 19 lbs but 4 hole like the fords. With a mostly stick engine, you probably don't need more than the stock injectors. The better atomization of the 4 hole injectors will smooth out the idle though.
