Author Topic: My jeep sucks  (Read 428 times)
My jeep sucks
« on: September 22, 2017, 11:41:11 AM »
pulled in the driveway yesterday and it died out of no where
drove to work today, engine hiccuped like it wanted to die then continued the journey
first thought was fuel pump or ignition switch. ruled out ignition temporarily since jiggling the key dosnt kill it. also drove to work with only the key not the ball of keys.
fuel pump is original but when it died it wasnt a starving the fuel kind of die
crank position sensor ? Would it restart like normal if the sensor was fawked ?
Offline Prof_Oaks
Re: My jeep sucks
« Reply #1 on: September 22, 2017, 11:42:46 AM »
Maybe an intermittent cps?  I’ve seen them act up if they get covered in oil from a leak.  Maybe a bad ground somewhere?
Re: My jeep sucks
« Reply #2 on: September 22, 2017, 11:46:50 AM »
I had that happen to 4.0 in my YJ.  Thought it was the CPS or coil (or coil wire), could be the ECM too.  I replaced the coil & wire and it seemed to go away.  Would always start right up after cutting out.  Carry a spare CPS just in case
Re: My jeep sucks
« Reply #3 on: September 22, 2017, 11:49:57 AM »
when i built the frame the crank position sensor was not on my mind...
To pull the sensor out of the bell housing, i will need to cut a hole in the floor.
I can barely reach my hand up there.
Im glad to know im not the only one with this issue
Re: My jeep sucks
« Reply #4 on: September 22, 2017, 11:50:57 AM »
A bad ground is an interesting thought
Re: My jeep sucks
« Reply #5 on: September 22, 2017, 11:51:30 AM »
I swapped out the coil 1st because the CPS is a bitch to get to!
Re: My jeep sucks
« Reply #6 on: September 22, 2017, 11:53:00 AM »
when it's running is running normally? normal power etc...?
Re: My jeep sucks
« Reply #7 on: September 22, 2017, 11:53:16 AM »
When Masers XJ wouldn't start at the MW trip 2015, he said it ended up being the coil. We tested for spark and got spark, but I guess it wasn't enough. The irony is that Ron had a spare coil and it would have been a 10 minute fix, or even a 10 minute shot in the dark. We ended up changing the CPS, but that wasn't it.
This wasn't intermittent though.
Re: My jeep sucks
« Reply #8 on: September 22, 2017, 11:59:20 AM »
When the engine is running, its gutless like usual.....
I kinda wanna get this sorted out before rocktober
Offline MattG
  • Probie of the year!
Re: My jeep sucks
« Reply #9 on: September 22, 2017, 12:18:08 PM »
@harryhood
Re: My jeep sucks
« Reply #10 on: September 22, 2017, 12:21:44 PM »
Matt is the purple one !
That was a fun night
Re: My jeep sucks
« Reply #11 on: September 22, 2017, 12:25:32 PM »
we got her done
Re: My jeep sucks
« Reply #12 on: September 22, 2017, 12:28:03 PM »
so maybe:
coil
cam position sensor
I don't think failing fuel pump would be so completely intermittent.
Re: My jeep sucks
« Reply #13 on: September 22, 2017, 12:30:03 PM »
is there a Cam sensor ?
ill pick up a crank sensor and a coil
Re: My jeep sucks
« Reply #14 on: September 22, 2017, 12:30:52 PM »
inside the dizzy
Offline MassJK
Re: My jeep sucks
« Reply #15 on: September 22, 2017, 12:33:43 PM »
Check for frayed wires on the back of the head. Change the coil first  then the cps then the fuel pump then the ecm
Re: My jeep sucks
« Reply #16 on: September 22, 2017, 12:36:30 PM »
My YJ acted like that and was cps. Try getting at it from underneath believe it or not. Can be done from up top using the force. However you may have the motor further back than stock.
Re: My jeep sucks
« Reply #17 on: September 22, 2017, 12:37:42 PM »
Diesel swap! :mrgreen:
Re: My jeep sucks
« Reply #18 on: September 22, 2017, 12:50:32 PM »
Ill give this a shot
inside the dizzy
didnt know that
jeep weighs enough as it is, but yes please
Offline XJRV-Maki
  • salt no carry
Re: My jeep sucks
« Reply #19 on: September 22, 2017, 01:11:11 PM »
can you drop the crossmember and let the tranny hang a little to get better access
Re: My jeep sucks
« Reply #20 on: September 22, 2017, 01:20:44 PM »
doubtful, the motor is so tight to the firewall, the back of the head will hit if it drops at all.
Re: My jeep sucks
« Reply #21 on: September 22, 2017, 01:28:00 PM »
Pull the motor mounts and droop the motor...
Re: My jeep sucks
« Reply #22 on: September 22, 2017, 09:25:39 PM »
This is how I have always done it in my YJ and all the XJ's. About 3 ft of extension and a swivel on the end. Works every time once the transmission is dropped a couple inches.
