Author Topic: 2.5L - Low Output  (Read 890 times)
Offline joe98tj
Re: 2.5L - Low Output
« Reply #25 on: November 10, 2017, 10:37:06 AM »
Waiting on the weekend for sunshine to make measurements for the outboard kit. Gonna go grab the skids from clayton next week and hopefully have it all finish welded. In a few weeks. In the mean time I started pulling apart the Dana 30 and planning out all the fancy parts ill be looking to install.
Mean, Green, Sticker Machine
« Reply #26 on: November 10, 2017, 11:00:36 AM »
progress
Offline joe98tj
« Reply #27 on: November 11, 2017, 03:29:50 PM »
Marked out the location of the frame cuts for the outboard notch. Was gonna cut today but ended having to fix some stuff on the lawn tractor.
With the sun out I did some measuring on the jeep. With normal weight in the rear on a flat surface it measured out that its 17 inches from the axle shock mount to the top of frame where the notch will be. With the rear coil correction kit ill probably plan for another .5" - 1". The uncut clayton frame mount sits another 5 inches above the frame.
Time to crunch some numbers and start looking for shocks. Probably make some more measurements tomorrow just to double check everything.
Offline joe98tj
« Reply #28 on: November 15, 2017, 02:40:57 PM »
Took today off to get some stuff done. Drove up to clayton this morning to grab some skid plates. Ive got them all bolted up so now its time for the fun part. Looking for suggetions on whats a good way to approach fabricating some mounting points for the engine skid.
« Reply #29 on: November 16, 2017, 03:00:32 PM »
I went up to the motor mounts off the frame rails in front.  Attached the rear to the existing cross-member by welding on some angle iron tabs.
« Reply #30 on: November 16, 2017, 03:17:41 PM »
I would use some box tubing just smaller than the bolt circle, then make a flanges plate to weld to the box tubing. easy to unbolt
Offline joe98tj
« Reply #31 on: November 16, 2017, 03:18:18 PM »
I'm thinking of cutting the current ends off, bending the passenger side, making new frame connection points with square tubing that will fit over the current to get more solid weld points, and bolting through the frame.
Offline joe98tj
« Reply #32 on: November 16, 2017, 03:26:09 PM »
Not picturing that too clearly in my head
« Reply #33 on: November 16, 2017, 06:05:21 PM »
Weld a flange with the matching bolt pattern to the end of some square tube and weld the tube to the frame. Then you can have an unmodified skid that bolts up as intended and it will be solidly mounted to the frame still. You can always add more support to the piece that goes to the frame as needed.
Offline joe98tj
« Reply #34 on: November 16, 2017, 06:28:15 PM »
My only concern with not being flush to the frame is something eventually getting in the way.
Offline joe98tj
« Reply #35 on: November 16, 2017, 07:52:14 PM »
However that does sound like the easiest way to tackle it and it woukd only stick out a few inches on each side.
Offline joe98tj
« Reply #36 on: December 04, 2017, 10:15:01 PM »
Progress has been slight to none while waiting on my brother to get some free time away from his newborn. Another reason not to have kids and another reason I should learn how to weld. Once I get him to do one last round of welding she'll be off to paint.
Spent half a day sand blasting the front axle. Another half day and it should be spotless. Also picked up Pete's now old to him tire carrier. Although its angled it fit with the hard top. A soft top looks to be in my future though. A new rim with a better offset should work well when I go up 35s, unless I ever get the motivation to cut it and weld it straight. Just need to drill new holes for the bolt pattern and then give it a coat of paint. Looking forward to getting the hi lift off the hood so I can open the hood all the way back to the window again.
« Reply #37 on: December 05, 2017, 07:47:44 AM »
Repurposing, i love it!!
« Reply #38 on: December 05, 2017, 12:10:13 PM »
Those rims look familiar...
« Reply #39 on: December 05, 2017, 12:14:14 PM »
Looks great Joe! Nothing like some swirly chrome goodness.  :cool:
Offline joe98tj
« Reply #40 on: December 05, 2017, 01:38:40 PM »
Sadly i'll be parting ways with it sometime soon
« Reply #41 on: December 05, 2017, 01:43:47 PM »
They had a good run in NEJeep! and I still have one lol
Offline joe98tj
« Reply #42 on: December 05, 2017, 01:44:57 PM »
You can have two if you would like
« Reply #43 on: December 05, 2017, 06:20:34 PM »
You must keep it. It must be memorialized and passed down generation to generation. Kind of like Truck naked girl mud flaps...
Offline joe98tj
« Reply #44 on: December 28, 2017, 07:52:11 PM »
More slow progress, baby was having issues so all we got done was tacking most of it in. Still working on making choices for the shocks which I can just tack in myself. Guess ill be waiting another month till its all buttoned up and ready for paint
