Author Topic: 2.5L - Low Output  (Read 1527 times)
Offline NickMaida
  • Mall Crawler
Re: 2.5L - Low Output
« Reply #50 on: February 13, 2018, 09:19:40 AM »
Are you using a tent as a paint booth?
'97 TJ 4.0 - 35s
Online joe98tj
« Reply #51 on: February 13, 2018, 09:29:53 AM »
Sandblasting
Mean, Green, Sticker Machine
98 wrangler • 4 cylinder • in progress •
2014 Ram Power Wagon Tow Rig/World Class Gas Guzzler
Offline NickMaida
  • Mall Crawler
« Reply #52 on: February 13, 2018, 09:32:37 AM »
That's fantastic. Love it.
'97 TJ 4.0 - 35s
Online joe98tj
« Reply #53 on: February 13, 2018, 09:49:34 AM »
It was alans idea
Sent from my VS987 using Tapatalk
Online joe98tj
« Reply #54 on: February 13, 2018, 01:56:12 PM »
Just carry a 2wd stub shaft and a stock unit bearing, then you can always limp it home if needed without worrying about your wheel falling off. I have an extra 2wd outer if you want it.
I should be fine to wait on buying a spare set. Why would I need a spare unit bearing though?
Offline RedJeepster1
« Reply #55 on: February 13, 2018, 01:59:14 PM »
When you say 30 spline shafts, I assume you mean inner and outer. If you run a 30 spline outer, you need a 30 spline unit bearing. If you used a 27 spline stub to get off the trail, you would want a unit bearing to match.
88 YJ, D30, D35, 4.10's, 4.6L Stroker, MPFI, Skyjacker 2.5" Lift, 33's
00 XJ, HP30, Front Truss, WJ Knuckles, High Steer, 3 link, Locked C8.25 w/ Chromo's, IRO Leafs, 4.56's, Rebuilt 4.0, JK Rubi Wheels, 35's
Online joe98tj
« Reply #56 on: February 13, 2018, 02:02:29 PM »
Oh, yeah I didnt think really think about the outer sincer the ones I was looking at came 30 inner 27 outer
Offline Mr. Easy
  • Administrator
    • 72 scamp
« Reply #57 on: February 13, 2018, 02:05:57 PM »
my G2 shafts are 30 inner / 27 outer
"it's like you're playing the triangle"
Online joe98tj
« Reply #58 on: February 13, 2018, 02:08:42 PM »
The g2 ones were the ones I was looking at. Rustys sells the ten factory ones but they don't specify the outer
« Reply #59 on: February 13, 2018, 02:33:20 PM »
I believe the only company using a 30 spline outer is Alloy USA.
« Reply #60 on: February 13, 2018, 07:26:58 PM »
I had Alloy USA in the YJ and it used factory unit bearings
Online A new level
« Reply #61 on: February 13, 2018, 07:31:04 PM »
Too bad you weren't getting axles when I had a group buy hookup. I might still be able to get a deal. Let me know what you'd like.
'16 JKR, Rock Krawler 3.5" Long Arm Off-Road Pro, 35" Nitto Trail Graplers
 Build thread http://forum.northeastjeep.org/index.php?topic=38405.new#new
Online joe98tj
« Reply #62 on: February 13, 2018, 07:32:16 PM »
Gonna be awhile, gotta get the new frame in first
Online A new level
« Reply #63 on: February 13, 2018, 07:41:32 PM »
All good. Hit me up when you're ready
Online joe98tj
« Reply #64 on: February 17, 2018, 05:46:35 PM »
Made some good progress today. A huge thanks to Pat for coming out and helping a few times and doing some welding. Got the suspension swapped over to the new frame. Hopefully the snow will melt some tomorrow afternoon and I can get the spring perches and shock towers melted in.
Offline YJScrounge
« Reply #65 on: February 17, 2018, 07:53:36 PM »
u r welcome!
"This situation requires an immature act be carried out on someone's behalf - We're just the guys to do it!" - Animal House
93YJ: Waggy 44 HD's F&R, Rear Detroit Locker, Front Eaton Elec Selectable, 5:13 Motive, Anti-Wrap Bar, WARN Hubs, 6" Lift on 35" Mud Terrains, 4.0 HO w/K&N Air Tube, Live Wire Ignition, WARN 8,000 lb Winch, AtoZ Cage and Sliders, FX Tuner Seats w/Harnesses, OBA, SOA
01 RAM Cummins Tow Rig
01 WJ: Son's DD/Mall Crawler, 2" Budget Boost, Skyjacker Shocks, JK 17" Wheels back-up Tow Rig
  • "Don't lose your Dinosaur"  - Dr. Doback
« Reply #66 on: February 17, 2018, 08:58:43 PM »
Great work! The ambition and energy is staggering.
Offline YJScrounge
« Reply #67 on: February 17, 2018, 09:38:29 PM »
Joe, have you looked outside? You’re not doing jack didly tomorrow. :eek:
Online joe98tj
« Reply #68 on: February 17, 2018, 09:44:57 PM »
I know.... I'm currently out drowning my sorrows with miller lite. Hopefully I can pick it up on monday
Online A new level
« Reply #69 on: February 18, 2018, 07:09:30 AM »
Looking good!
Offline MassJK
« Reply #70 on: February 18, 2018, 08:12:28 AM »
Even sorrows should be drowned with something better
Online A new level
« Reply #71 on: February 18, 2018, 08:13:46 AM »
Agreed!
Offline YJScrounge
« Reply #72 on: February 18, 2018, 08:15:53 AM »
He's a kid from Derby. He doesn't know any better...
Online joe98tj
« Reply #73 on: February 18, 2018, 08:24:24 AM »
This
Offline HankD
« Reply #74 on: February 18, 2018, 09:09:49 AM »
He thinks he's a Gas Monkey?
nada! Shopping for parts for new build.
