Author Topic: Frame care suggestions  (Read 1202 times)
Online Horn
« on: October 12, 2017, 04:38:36 PM »
Last February when I got the LJ I hit the outside of the frame with a few cans of Fluid Film. This summer I cleaned the inside out thoroughly. Not much came out. Then for what it's worth I used Eastwood internal frame coating on it. I read mixed opinions but figured it wasn't going to do any harm even if it didn't do a lot of good.
Now I'm thinking of the outside. The whole thing seems pretty consistently in the same shape. When I dropped the skid this summer there was a little more rust between frame and skid and I wire wheeled that down and hit it with some Rustoleum.
The question is what's my next step planning ahead. I've always assumed some kind of section by section thorough cleaning and painting and annual inspection and touch up. I know there are a lot of options out there. Curious what suggestions people have. Then I'll make a plan and stick to it.
Re: Frame care suggestions
« Reply #1 on: October 12, 2017, 05:32:02 PM »
I started with a 74 CJ chassis and power washed it as it was an open channel frame. After I boxed it in I used "Duplicolor" (white can black label )   spray rust proofing. They make two different kinds and I prefer the sand finish to the rubberized finish. On the floors it would get hot enough in the summer that it would stick to your boots and the rubber matts would have to be pealed out to wash.  The frame looks just as good 10 yrs. latter and touch up is a spray away. All my street vehicles Ive always painted the whole underside with an 8 dollar quart of Rustoleum , frame , floors, inside fenders , what ever I could get to with my spray gun. The quart has to be reduced but you can control how thin you make it compared to a rattle can , there just isnt enough pigment in it to cover a large area. There also is a product called "POR-15" which uses rust as a catalyst to activate it to harden. They recommend a top coat product also because of UVs. I dont see the frame as being subjected to direct sunlight all the time. Its not cheap , but the wright ups on it sound promising . Yours being newer , if you have a compressor , Id get a quart and keep up with it.  FjR68
Online A new level
« Reply #2 on: October 12, 2017, 05:40:24 PM »
X2 POR-15.
« Reply #3 on: October 12, 2017, 05:59:41 PM »
Chassis Saver similar to POR 15. Is activated by moisture believe it of not so will smother the rust. Aint cheap, $100 per gallon.
Rustolium is always the inexpensive reliable backup. Have been using it for years as well.
Online JeepinMaxx
« Reply #4 on: October 12, 2017, 06:09:35 PM »
I just hit mine with rustoleum every once in a while...  Fluid Film for inside the frame just the previous owner did
Online Horn
« Reply #5 on: October 12, 2017, 06:31:31 PM »
How do you get the Fluid Film sprayed inside evenly? I didn't spray it inside last year because I knew I was going to do the internal coating in the summer.  Now I wish I had kept the special nozzles that came with the Eastwood cans for spraying inside.
« Reply #6 on: October 12, 2017, 07:12:20 PM »
I think you still have too much paint for POR15.  It likes to grab onto rust.  From your pics, I would use a wire wheel and Rustoleum.
« Reply #7 on: October 12, 2017, 07:27:41 PM »
^^^^^^^This^^^^^^^
Online JeepinMaxx
« Reply #8 on: October 13, 2017, 09:18:49 AM »
https://www.amazon.com/Fluid-Film-Spray-Extension-Wand/dp/B00CLUGXFI/ref=pd_lpo_vtph_60_lp_t_2?_encoding=UTF8&psc=1&refRID=5JXJTB3F6DBCDEP5E58G
Offline NickMaida
« Reply #9 on: October 13, 2017, 10:04:59 AM »
Or, if you have an air compressor, I've heard you can use the eastwood undercoating gun and just use the 1 gallon fluid film buckets from Napa. I don't have personal experience with this. I'm going to try it this winter and see how it goes.
http://www.eastwood.com/undercoating-gun-with-2-hoses-and-bottle.html
And to repeat some of what has been stated. I'd get a 4.5" angle grinder with a wire cup and hit all the rust spots. (100x better than doing it manually and way better than any other method I've tried). Scuff up the paint on the non rusty areas, then POR15 the rust spots (I'd recommend getting the entire kit with degreaser and metal prep), then rustoleum the entire frame (including the POR15 spots) while the POR is still tacky.
A little bit complicated and time consuming, but it works.
'97 TJ 4.0 - 35s
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
« Reply #10 on: October 13, 2017, 11:45:44 AM »
fluid film, Can it be put on using a reg.  1 gal. lawn weed type sprayer
Offline 50willysM38
« Reply #11 on: October 13, 2017, 01:29:20 PM »
Fluid film actually makes a gun specifically for their product. It works great. Even came with a 2 foot extension tube for spraying inside frames.
Stock Willys M38
Offline 50willysM38
« Reply #12 on: October 13, 2017, 01:30:51 PM »
Farmington valley equipment in Farmington has the best prices on fluid film and the guns that I have found. eBay and amazon are over priced
Stock Willys M38
Online joe98tj
« Reply #13 on: October 13, 2017, 04:24:09 PM »
Buy a beater, let the jeep sit during the winter
Mean, Green, Sticker Machine
Online Horn
« Reply #14 on: October 13, 2017, 08:25:34 PM »
I love it when a plan comes together.
This winter I'll thoroughly Fluid Film inside and out. Only question is which application method I use. I've got some good options. Next spring or summer I'll do the exterior frame cleaning and some spot treatment and then paint everything I can get to.
« Reply #15 on: October 13, 2017, 08:29:00 PM »
There was a few years in a row when my Jeep was broken each winter... Worked out well, not it just sits...
« Reply #16 on: October 13, 2017, 09:10:03 PM »
Drill a couple holes at the bottom of the curve in front of the rear tires
Online Horn
« Reply #17 on: October 20, 2017, 07:56:42 AM »
In front of or behind the control arm bracket?  If behind does that mean removing the control arm so I can drill from underneath or would the lower edge right where my finger is work?
« Reply #18 on: October 20, 2017, 08:01:28 AM »
where your first picture shows, in the center of the frame. the biggest issue is that crap collects in there, and has no way to get out
The other thing is being diligent about cleaning out mud
« Reply #19 on: October 20, 2017, 08:02:46 AM »
Newer TJs have holes at the bottom of the frame already.  I just flush out the frame everytime I wash or wheel it.  You can actually run a hose through almost the whole frame.
Offline Johnny Cupcakes
« Reply #20 on: October 21, 2017, 09:00:08 PM »
Park it and get a cheap hoopty for winter
Online joe98tj
« Reply #21 on: October 21, 2017, 10:13:03 PM »
Or a very expensive hoopty that can tow the jeep everywhere
Offline The Navy Commander
  • Shaq City is the place to rock. Semper Fi diddy
« Reply #22 on: November 06, 2017, 08:19:18 PM »
I was actually thinking of doing the new Truck and the Jeep. Who wants to have Fluid Film Party???
Will probably get the two gallon kit.
Superwinch EPi 9.0 Detours Custom Bumpers/Dropkicks, 3.5" RE Superflex Lift, 1" Daystar Body Lift, 15" Cragar Street Lock D, 33" Dick Cepek Crushers,
Solid Axle Diff Covers, Jeep Medic Belly Up Transmission/Engine Skid Plate Combo, Other Kirby+Skid Row stuff
Blessed are those who, in the face of death, concern themselves only with the front sight post...
Online joe98tj
« Reply #23 on: November 06, 2017, 08:31:03 PM »
I'm looking to fluid film mine soon
Online MassJK
« Reply #24 on: November 06, 2017, 08:36:40 PM »
