Author Topic: adams or woods  (Read 863 times)
Re: adams or woods
« Reply #50 on: November 30, 2017, 08:36:43 PM »
is a 1310 stronger than a OEM jeep axle? just curious
Re: adams or woods
« Reply #51 on: November 30, 2017, 10:18:13 PM »
There are some people that think a 1310 is stronger than a 1350.
Your better off with a 1310 because it is a short shaft and a 1310 can deliver a higher angle geometry than a 1350.
Re: adams or woods
« Reply #52 on: November 30, 2017, 10:30:06 PM »
The 1310 U-joint is just a size that matches many drive train components on a stock or modified Jeep.  More important are the manufacturers and designs, lubrication paths, etc of the U-Joint in regards to "stronger"
Re: adams or woods
« Reply #53 on: December 01, 2017, 09:33:12 AM »
Thanks again
Re: adams or woods
« Reply #54 on: December 09, 2017, 10:12:15 AM »
can you over tighten the front adams t case yoke? I know the rear you can... I brought the nut down with an impact to just a hair of play in the yoke, then torqued to 160ftlbs... Just wondering if i should re-do with a ratchet to be more precise...
Online Mr. Easy
Re: adams or woods
« Reply #55 on: December 10, 2017, 05:07:10 PM »
 You had to change the joke? Did you measure the preload (rotational torque) before removing the factory yoke and check with the new on after?
Offline BC Miller
Re: adams or woods
« Reply #56 on: December 10, 2017, 05:58:22 PM »
You're talking about the yoke on the t-case side, correct?  Not the pinion flange on the diff?  If so, I don't think there are any crush sleeves to worry about over crushing.  When I installed my Adams DS, I torqued my t-case yoke nut to 150 ftlbs (with red thread locker on the nut) and it's been fine for 2 years now.
Re: adams or woods
« Reply #57 on: December 10, 2017, 06:17:15 PM »
yes the t-case side only, front drive shaft ...(not the pinion flange on the diff).....
I torqued  my t-case side to 160ft/bls per adams instructions...
glad to hear i didn't over tighten..
thanks again
