Author Topic: Front D30 Diff Cover Choices  (Read 143 times)
« on: October 26, 2017, 09:12:48 PM »
My TJ came with a CRANE front diff cover like this one (minus the gouges...)
When cleaning up my office I found a SOLID brand D30 cover I bought for my old YJ several years ago...
Any advantage to switching to the SOLID brand one?  The CRANE cover doesn't have the cast ribs - maybe the previous owner went with that one to clear the thicker Currie Steering set up?
Just deciding if I should keep the old CRANE cover and sell the SOLID cover (BTW - the CRANE cover looks like it has the fill hole in the correct location for a front diff)
Re: Front D30 Diff Cover Choices
« Reply #1 on: October 26, 2017, 09:20:14 PM »
That Crane is similar to the Riddler i have. I switched to the Crane Riddler because it was low profile and cleared my 1-ton steering.
« Reply #2 on: October 26, 2017, 10:06:44 PM »
That Crane is similar to the Riddler i have. I switched to the Crane because it was low profile and cleared my 1-ton steering.
  That's the way I was thinking...  I think I had a Crane or Riddler on the D44 rear Diff on my old YJ (it was painted green like that!)
I think I'll stick with the current set up then and sell the SOLID
Here's a fun Diff cover test I saw a decade ago
http://www.fourwheeler.com/how-to/transmission-drivetrain/154-0708-bulletproof-test/
« Reply #3 on: October 27, 2017, 06:49:04 PM »
Does a D30 Diff cover for a YJ/TJ fit a JK D30?
