Author Topic: Best gear oil  (Read 354 times)
Best gear oil
« on: November 09, 2017, 09:15:11 PM »
What are you guys running for gear oil? I’ve been running mopar 80w90 with no issues but wonder if I should switch to synthetic ..
What’s the best for 456 and lockers ?
Thanks in advance
Re: Best gear oil
« Reply #1 on: November 09, 2017, 10:17:45 PM »
Royal Purple.
Re: Best gear oil
« Reply #2 on: November 09, 2017, 10:31:14 PM »
Two answers to the same question...
For break in of new 4.56 gears follow the manufacturer's break in:  varied MPH, Miles, Heat cycle and use conventional dino gear oil for break in...  Drain the break in oil then fill with your favorite synthetic and drive for a 100 miles, then drain it and put the final fill of your favorite synthetic (I prefer Royal Purple since we use it for everything at work, but Mobil 1 is OK...  I personally stay away from Redline)
For longevity on the road (or wheeling) with 4:56 and a limited slip or locker synthetic works.  If you have leaky axle seals stick with dino oil since you will have to change it after every wheeling trip with a water crossing  :wink:
Re: Best gear oil
« Reply #3 on: November 10, 2017, 06:01:39 AM »
I can't think of any reason that the ratio makes a difference on what oil to run.
Dyno is fine as long as you change it as your driving habits dictate.
Offline CitizenwithJeep
Re: Best gear oil
« Reply #4 on: November 10, 2017, 08:13:22 AM »
I saw somewhere on the internet that if you have air lockers, use dino not synthetic.
Re: Best gear oil
« Reply #5 on: November 10, 2017, 08:32:01 AM »
cheapest stuff walmart sells, change often
Re: Best gear oil
« Reply #6 on: November 10, 2017, 08:34:57 AM »
This is what I do!  Except the change often part.  If it's not contaminated, I don't change it on a schedule.
Offline mustangx
  • Newbie
Re: Best gear oil
« Reply #7 on: November 10, 2017, 08:50:27 AM »
I'm nota fan of cheap. I use lucas for my dif's and mobil 1 for the engine. 280k and going strong.
05 TJ, Rocky Mountain Edition. 4"suspension, 1"body lift, tummy tuck, 37's,456 gears, chrome alloys front and rear, sye and custom driveshafts, over the knuckle steering. fox long travel shocks, fully armored
Re: Best gear oil
« Reply #8 on: November 10, 2017, 08:56:09 AM »
Your Jeep has 280k Todd? Wow!
Online RedJeepster1
Re: Best gear oil
« Reply #9 on: November 10, 2017, 09:46:27 AM »
I use cheap oil also and just check it from time to time. My rear axle has 360k on it, although the old gear set was definitely pretty loose... My front axle with the same mileage is in great shape still, just running cheap Dino oil.
Offline MattG
  • Probie of the year!
Re: Best gear oil
« Reply #10 on: November 10, 2017, 11:45:48 AM »
Unless you are running a LSD diff, any oil will do.
I ran Valvoline, worked great. We go through water and mud, it gets in. Why waste $$$ on expensive stuff thats gonna get ruined quick
Re: Best gear oil
« Reply #11 on: November 10, 2017, 12:03:25 PM »
As far as weight, I have found heavier oil makes my auto lockers behave better on the street.
Re: Best gear oil
« Reply #12 on: November 10, 2017, 03:18:15 PM »
I  always run full synthetic in my engines, until they leak too bad to handle it.  Then I switch over to Quaker State Dino oil.
An old timer told me that Quaker State oil has more paraffin in it than other oils and if you have a leaker it will make a difference.  It really does!
Re: Best gear oil
« Reply #13 on: November 10, 2017, 06:10:48 PM »
Yup, and that paraffin builds up over time. :eek:
Re: Best gear oil
« Reply #14 on: November 10, 2017, 06:15:31 PM »
excellent !! anyone use amsoil?
Offline MassJK
Re: Best gear oil
« Reply #15 on: November 10, 2017, 07:08:44 PM »
lol
Re: Best gear oil
« Reply #16 on: November 10, 2017, 08:05:46 PM »
On a motor with over 200K that means less leaks.
Re: Best gear oil
« Reply #17 on: November 10, 2017, 09:25:50 PM »
I suppose it doesn't matter at that point. :rotflmao:
Re: Best gear oil
« Reply #18 on: November 11, 2017, 07:09:34 AM »
Gorilla said it best , Heavy oil makes the auto lockers work better and smoother. Ive been using 85/140 in my whole drivetrain for 15 yrs. We dont do normal driving , even if you only do greens and some blues. We work our stuff to death. "Brand"  Thats just guess work ! What you saw your father using. Whats on sale. Im a Pennzoil guy and you will never change my mind. Ive seen the inside of Engines,Trans.T-Cases, and diffs. They dont lie if you really look.  Changing your oil is cheap insurance to longevity.  FjR68
Offline Angrytj
  • Luciano
    • My YouTube channel
Re: Best gear oil
« Reply #19 on: November 11, 2017, 07:33:16 AM »
I use 75W140 mobil 1 synthetic
2005 Jeep Wrangler Rubicon, 35s, 5in rear stretch, Poison Spyder hiline defender front fenders and rear armor, Rokmen Sliders, custom hiline hood, Synergy front half and custom rear half roll cage, Mastercraft seats, 4pt harness, TJ rubi 44 axles, ARBs, 488 gears, chromo shafts, truss front and rear, front axle is sleeved, tie rod flip, PSC hydro assist steering box and ram, Vanco big brake kit, Raceline beadlocks and other little things.
Re: Best gear oil
« Reply #20 on: November 11, 2017, 10:30:37 PM »
Pete at CT axle told me to keep using whatever brand 80W90
