Author Topic: tera flex covers how much gear oil you getting in?  (Read 163 times)
« on: November 12, 2017, 11:39:03 AM »
Just did my diffs cleaned n oiled....However I got 2 1/2 quarts in 44 but only 1 quart in d30...I tried to force a little more but it came at me twice as fast....anyone getting more that a quart in there d30 , not sure if the tera flex cover makes a difference
Offline XJRV-Maki
  • salt no carry
Re: tera flex covers how much gear oil you getting in?
« Reply #1 on: November 12, 2017, 12:27:23 PM »
D30 standard capacity is 1.1 quarts, if you put 1 quart in and you can't puts no more then I'd call it good to go.
« Reply #2 on: November 12, 2017, 04:55:24 PM »
yea i tried to put more in but it came out as fast i could squeeze ...... Good to go!
« Reply #3 on: November 13, 2017, 07:49:42 AM »
The 30 only needs enough oil for the R&P cause there are no axle bearings to lubricate . General rule is fill to spill.  Although , if your pinion has been rotated up for DS angle , You may have to measure the amount you have to put in if the fill is is the cover.   FjR68
Offline XJRV-Maki
  • salt no carry
« Reply #4 on: November 13, 2017, 11:39:44 AM »
And if you wanted to get more in - which I don't think you need to do - but you could add another pint or so by getting the front tires up on a steep hill, a ledge, stone wall or the like.
« Reply #5 on: November 13, 2017, 08:07:02 PM »
thanks appreciate all the great info... ,,i think I'm good...2.5 inch RK lift , not too much angle.....
