Author Topic: Body work  (Read 167 times)
Offline MattG
  • Probie of the year!
Body work
« on: November 30, 2017, 09:34:03 AM »
I had a blow out in my Mazda 3, it did some damage to the car.
It destroyed the inner fender plastic, and cracked the rear bumper, and knocked off my side skirt.
I want to clean this area up before I put the side skirt back on.
I’m not the best at body work, any tips.
Offline Dollar Store petite pants
  • I got my swin trunks and my flippy floppys
Re: Body work
« Reply #1 on: November 30, 2017, 09:36:21 AM »
some type of rust reformer and make sure it dries for 24 hours before you out paint on it.
95 YJ, 4.0 Turbo
96 Ford F-350 Powerstroke
2001 BMW 540i M-sport 6 speed
2001 Volvo V70
Online Mr. Easy
Re: Body work
« Reply #2 on: November 30, 2017, 09:37:24 AM »
what he said. I trust rustbullet for this type of work
Re: Body work
« Reply #3 on: November 30, 2017, 09:42:04 AM »
white rustoleum with a roller
Online A new level
Re: Body work
« Reply #4 on: November 30, 2017, 09:58:40 AM »
All depends on how fancy you want to get and how much the car is worth
Re: Body work
« Reply #5 on: November 30, 2017, 10:00:30 AM »
only the best for the mazda rotti
Re: Body work
« Reply #6 on: November 30, 2017, 10:10:56 AM »
BONDO!!! :mrgreen:
Re: Body work
« Reply #7 on: November 30, 2017, 10:31:18 AM »
 Clean it, rust prohibitor, wait 24 hrs, prime, wait 24 hrs, top coat.
Its cold now, you need a heated area to do this right.
Re: Body work
« Reply #8 on: November 30, 2017, 10:53:03 AM »
BONDO!!!!!
and a heat gun! :mrgreen:
Offline XJRV-Maki
  • salt no carry
Re: Body work
« Reply #9 on: November 30, 2017, 11:05:56 AM »
sawzall  :rolleyes:
Offline SJJEEP
  • CAR KILLER
    • sjjeep.com
Re: Body work
« Reply #10 on: November 30, 2017, 01:07:17 PM »
Phosphoric Acid
Re: Body work
« Reply #11 on: November 30, 2017, 01:16:02 PM »
Oh I know!
Step one.  Cut hole in roof, trunk and hood.
Step two.  Place 50lb bag of rock salt in each hole.
Step three.  Wait.
Problem should be solved within 2 to 3 years. :mrgreen:
Re: Body work
« Reply #12 on: November 30, 2017, 01:37:19 PM »
Are you going to address the other side as well? I'm sure it isn't an isolated problem. If your only planning to do this side, I wouldn't put much into it. Even if this side lasts, the other side will rust out under the plastics anyway.
