Author Topic: Body and Motor Mount Lift  (Read 477 times)
Re: Body and Motor Mount Lift
« Reply #25 on: December 29, 2017, 04:38:47 PM »
I needed a body lift to fit the ultra high clearance skid that I am running.
What high clearance skid are you running?  My TJ has one that I don't know the MFG, but I'd like to lose the body mount lift since I have all the tire clearance I need with the MetalCloak set up...  If you are on 35's - when you get a chance, take a measurement from the pavement to the bottom of the belly skid plate.  I'm at around 22" now
It's an undercover fab skid.
it's 21.5 inches to the bottom of the skid.
« Reply #26 on: December 30, 2017, 11:35:30 PM »
Sweet!  That 21"-22" clearance is what I have now...  I bought some 3.5" springs from an NEJeep member that I hope will drop the body/tub height down an inch - I'm getting old and need the lower step in height
Online YJScrounge
« Reply #27 on: December 31, 2017, 08:52:20 AM »
I took the 2" tub lift out two years ago. Brought it down to roughly 6" lift. Rig is more stable and getting in/out is easier. The only downside is I can't see/clean the top of the gas tank, frame rails, etc...
« Reply #28 on: December 31, 2017, 10:23:37 AM »
It's a pita for me to get in mine too. Kyle can almost get in by  himself. That will be awesome once that happens.
« Reply #29 on: December 31, 2017, 02:30:33 PM »
I have a set of JKS MML blocks.  40 buks in enfield     FjR68
