Author Topic: Wheel Bearings  (Read 500 times)
Offline Ryean78
Wheel Bearings
« on: December 12, 2017, 10:04:48 AM »
I have a few questions.
I am really annoyed with myself I just recently replaced the Axle and all associated parts except the wheel bearings that had 30,000 miles on them. Now I think the bearings are going bad. Drove the jeep yesterday and a really god awful sound was coming from the front end. I completely over looked this. :swear_mad:
1. How often are you guys going through wheel bearings?
2. What brand are you guys typically using?
3. Would a bad wheel bearing cause a vibration at higher speeds? There is a fine vibration above 50 MPH it gets worse as you get faster. Sounds like I have a Sub in the Jeep that is just playing a constant bass signal.
Thank you,
Ryean
Re: Wheel Bearings
« Reply #1 on: December 12, 2017, 10:08:42 AM »
I've heard JK wheel bearings really really don't like mud....
Re: Wheel Bearings
« Reply #2 on: December 12, 2017, 11:25:04 AM »
Thank you,
Ryean
1. It varies, but with 30k with wheeling (especially deep water/mud)  and larger tires and reduced backspacing, they could very well be bad.
2. Stay away from the economy brands like Duralast, go with Timken.
3. Yes, especially if the noise is proportional to speed, probably wheel bearings.
I'm 10 min away, so let me know if you need a hand or tools.
Offline Ryean78
Re: Wheel Bearings
« Reply #3 on: December 12, 2017, 11:36:56 AM »
Thank you Rey! That is what I thought. I am just annoyed with myself for not replacing the bearings when I had it apart. Good practice right! I will let you know if I need a hand I appreciate the offer!
Thank you,
Ryean
Offline MattG
  • Probie of the year!
Re: Wheel Bearings
« Reply #4 on: December 12, 2017, 01:08:36 PM »
as much as it sucks, we have all been there.
Better in your driveway than the trail.
I preferred the brake on the trail tho, more hands to help that way.... JK
Online Angrytj
  • Luciano
    • My YouTube channel
Re: Wheel Bearings
« Reply #5 on: December 12, 2017, 01:46:08 PM »
What Rey said... I also use Timken
2005 Jeep Wrangler Rubicon, 35s, 5in rear stretch, Poison Spyder hiline defender front fenders and rear armor, Rokmen Sliders, custom hiline hood, Synergy front half and custom rear half roll cage, Mastercraft seats, 4pt harness, TJ rubi 44 axles, ARBs, 488 gears, chromo shafts, truss front and rear, front axle is sleeved, tie rod flip, PSC hydro assist steering box and ram, Vanco big brake kit, Raceline beadlocks and other little things.
Re: Wheel Bearings
« Reply #6 on: December 12, 2017, 06:48:29 PM »
Best place for Timken is RockAuto.com.
Re: Wheel Bearings
« Reply #7 on: December 12, 2017, 07:18:29 PM »
Timken!  I hope you used plenty of anti seize when you put it back together - should come back apart easy...
Offline Mr. Clean
Re: Wheel Bearings
« Reply #8 on: December 12, 2017, 07:49:31 PM »
Timken.
Re: Wheel Bearings
« Reply #9 on: December 12, 2017, 07:55:31 PM »
Jack up one wheel at a time and rock the tire top to bottom.  See if there is any play.  If there is, the bearings are bad.  Do you have individual bearings or a unit bearing?  Usually, if a wheel bearing is whining you can get the noise to change as you move the steering wheel back and forth loading and unloading the bearing.  Find a big open parking lot and dive around in figure 8's and see if you can hear it change.
With that said, I have had bearings really loose and never felt it, or heard it on the road.
Offline MassJK
Re: Wheel Bearings
« Reply #10 on: December 12, 2017, 07:56:09 PM »
every rock auto timKen has been garbage.   I swear they are all knock off
Re: Wheel Bearings
« Reply #11 on: December 12, 2017, 07:57:03 PM »
All the National bearings I have put in recently are made in China these days.
Offline Ryean78
Re: Wheel Bearings
« Reply #12 on: December 12, 2017, 08:37:14 PM »
I called and looked everywhere for the Timken brand no one seems to carry them. I did not try Rock auto.
I did lift the front end this evening to see if there was any play in the wheel to my surprise it was tight. I also did the figure eight, the sound was there when I was turning to the driver side and going straight. I turned hard passenger and now it is gone, really weird. I was able to get it to do it again when I was in reverse turning passenger.
Offline Miley Cyrus
Re: Wheel Bearings
« Reply #13 on: December 12, 2017, 09:13:47 PM »
SKF is another quality brand for bearings most of the time rock auto has be cheapest prices and you always get a 5% discount all you have to do is google the discount for a code
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
Re: Wheel Bearings
« Reply #14 on: December 12, 2017, 09:31:41 PM »
 Parts geek has the timkens...
 Looks like Summit has em also... though they're spendy as fawk there...
 Also on Amazon... for various pricing...
 Also seen em on JCWhitney...
 Also on Newegg believe it or not!!!   :eek:
 And of course, also on the bay of eeees
Profile for Team_Oscar
Quote from: Theo Maassen
  • Honorary Members
Re: Wheel Bearings
« Reply #15 on: December 12, 2017, 09:39:17 PM »
 What year?
Re: Wheel Bearings
« Reply #16 on: December 12, 2017, 10:13:44 PM »
Must be the installer.  Mine still are fine. :rotflmao:
Re: Wheel Bearings
« Reply #17 on: December 13, 2017, 07:41:41 AM »
Turning hard passenger will put more load on the drivers side tire and take the load off the passenger side causing the noise to stop.
Offline XJRV-Maki
  • salt no carry
Re: Wheel Bearings
« Reply #18 on: December 13, 2017, 08:58:08 AM »
I've got a CAP auto parts store nearby that always has Timkin unit hubs in stock. Do what Terry said to see how much play there is, if it's bad replace it sooner than later, the result of one failing on Rt 2 West is not pretty...
Offline Ryean78
Re: Wheel Bearings
« Reply #19 on: December 13, 2017, 09:01:45 AM »
I found them on Rock auto Timken for 105.00 a piece. I ordered two, I might as well do both get it over with. (Piece of mind).
Offline Ryean78
Re: Wheel Bearings
« Reply #20 on: December 13, 2017, 09:03:54 AM »
I lifted the front last night there was no play at all. I was surprised...
Offline XJRV-Maki
  • salt no carry
Re: Wheel Bearings
« Reply #21 on: December 13, 2017, 10:29:46 AM »
Did you happen to spin the wheel while it was up to see if you could replicate the grinding noise?
Hubs are weird, they usually just whine as they go bad. By the time they get to "god awful" level in my experience that means they've got about a mile left before the wheel falls off.  :rotflmao:
Might as well change them anyways if you've got the parts, keep the old ones to make loaded spare shafts (nice not to have to mess with that 175 ft lb axle nut on the trail) but I wouldn't be shocked if the vibration and noise is still there and is coming from the driveshaft, U-joints, somewhere else.
Offline Ryean78
Re: Wheel Bearings
« Reply #22 on: December 13, 2017, 02:01:32 PM »
I did spin the tires to see if I could pinpoint exactly where the noise is coming from. Unfortunately I could not reproduce the noise. I just contributed it to not having a load on the wheels.
I do agree with you on getting rid of the vibration. I do not think this has anything to do with the wheel bearings (I am Hoping). I did have the front driveshaft rebuilt do to it being bent. I honestly think its either in the gear set up, or its something with the transfer case. The vibration is more harmonic you really don't feel it, but its visual in my rear view mirror and it sounds like I have a stereo system with a constant bass note being played.
Re: Wheel Bearings
« Reply #23 on: December 15, 2017, 07:02:20 AM »
I would think the unit bearing may not be as bad to have play but after sitting the bearings had time to pit and are damaged . I agree on while lifted they wouldnt make noise as the werent supporting any weight .   That vibration thing sounds bad . Id pull the DS and take her for a spin. See if they did their job. Usually a bent shaft get re-tubed not straightened. Then there is always did the balance it after they were done. Gotta start some where , its free and easy.     FjR68
Re: Wheel Bearings
« Reply #24 on: December 15, 2017, 08:11:28 AM »
Turn up the radio and enjoy the vibes!
Its a Jeep, not a Corvette. :mrgreen:
