Author Topic: double cardan  (Read 109 times)
double cardan
« on: December 19, 2017, 07:39:31 AM »
any difference in setting pinion on a double cardan adams..?  1 degree below pinion sound good?... so under load it should rotate to zero...in theory anyways.
Re: double cardan
« Reply #1 on: December 19, 2017, 07:46:16 AM »
Sounds reasonable. With leaf springs, I always set it 1-2" below, with links it won't move much if at all.
Re: double cardan
« Reply #2 on: December 19, 2017, 08:13:01 AM »
Yes, 1 degree down should do the trick. :mrgreen:
Re: double cardan
« Reply #3 on: December 19, 2017, 08:45:09 AM »
Excellent
Thanks guys
