Author Topic: TJ aftermarket upgrades for sale  (Read 412 times)
Offline Angrytj
  • Luciano
    • My YouTube channel
« on: December 19, 2017, 02:28:37 PM »
Looking to sell the following... For pictures send me a PM.
Also keep in mind everything is still on the jeep and I will have no time to strip items for sale until after the holidays.
Genright EXT gas tank - $800
Fox 2.0 remote reservoir shocks eyelet on both ends (10" travel) -$150 ea
Currie Ultimate Steering, the one with a heat treated tie rod (From my knowledge this is no longer sold) - $450
Vanco 16" Big Brake kit with machines knuckles to accept RCVs - $700
Pro Comp MT2s 35x12.5r15 with roughly 4000 miles set of 5 - $1000
15x8, 5x 4.5, 3.25 backspacing Raceline Monster Alum beadlocks powdercoated Prismatic Gold w/ aluminum ring painted black - $300 each
Front TJ Rubicon 44 axle: This axle is setup for a 3 link plus trac bar setup. 488 gears, ARB, stock axle shafts, Alloy axle seals, Sleeved, Clayton 3link truss/bridge, gusseted Cs, raised sway bar mounts, brand new hubs, Artec axle brackets, aftermarket balljoints, Riddler Diff cover- $2000
Rear TJ Rubicon 44 axle: This axle is setup for a 4 link no trac bar setup. 488 gears, ARB, Superior Chromo axle shafts, TNT truss, Artec brackets, Disc Brakes, Riddler Dif cover- $2000
ARB on board air/locker compressor w/ tire inflation kit- Will include if axles are purchased together otherwise selling for $200
Rubi 44 chromoly front shafts w/ brand new spicer ujoints - $500
Rubi 44 stock rear axle shafts - $75
3 front TJ rubicon driveshafts (all likely need a new ujoint that attaches to the axle) - $50 each
2 rear CV driveshafts (one is a Tom woods the other is custom stretched to fit a 5" rear wheelbase stretch) $150 for the Tom woods and $100 for the custom made.
Brand new in box Spicer ball joints (set of 4) Part #706944X - $100
Brand new in box Currectlync RH thread tie rod end part # CE-9701TRL $50
I think that's it. All items are in great shape and cross posted.
Sorry if you may feel I am asking a lot for some of these parts but from my research this is the going rate for these items.
Thank you everyone
2005 Jeep Wrangler Rubicon, 35s, 5in rear stretch, Poison Spyder hiline defender front fenders and rear armor, Rokmen Sliders, custom hiline hood, Synergy front half and custom rear half roll cage, Mastercraft seats, 4pt harness, TJ rubi 44 axles, ARBs, 488 gears, chromo shafts, truss front and rear, front axle is sleeved, tie rod flip, PSC hydro assist steering box and ram, Vanco big brake kit, Raceline beadlocks and other little things.
Offline Angrytj
  • Luciano
Re: TJ aftermarket upgrades for sale
« Reply #1 on: December 19, 2017, 02:37:01 PM »
Items are cross posted so I will ensure to keep available items updated.
Online JeepinMaxx
« Reply #2 on: December 19, 2017, 03:32:14 PM »
PM sent regarding the springs...
« Reply #3 on: December 19, 2017, 04:23:12 PM »
Have the front Rubi 44 Chromo shafts ever been installed?
Offline Angrytj
  • Luciano
« Reply #4 on: December 19, 2017, 04:30:45 PM »
Yes shafts are used with new ujoints just installed. They are currently in the axle
Offline Angrytj
  • Luciano
« Reply #5 on: December 19, 2017, 10:01:43 PM »
First post updated with a couple more items
Offline joe98tj
« Reply #6 on: December 20, 2017, 07:44:07 AM »
I'll take the ball joints
Mean, Green, Sticker Machine
Offline Angrytj
  • Luciano
« Reply #7 on: December 20, 2017, 12:01:15 PM »
They are yours. I’ll send you a PM
Offline Angrytj
  • Luciano
« Reply #8 on: January 09, 2018, 03:36:45 PM »
Front axle and gas tank are sold.
Big brake kit has a sale pending.
Rear axle price reduced to $1700
Tires reduced to 900 for 5 and Raceline beadlocks reduced to $1250 for 5 vs $1500
Offline Angrytj
  • Luciano
« Reply #9 on: January 09, 2018, 03:37:02 PM »
Pictures on all items still available coming hopefully later tonight
Offline Angrytj
  • Luciano
« Reply #10 on: January 12, 2018, 10:09:48 AM »
Few more items sold, wheels and tires are pending sale.
Remaining:
(4) Fox 2.0 remote res shocks 10" travel
Rear 44 axle
Genright EXT tank 19.5 gallons
Front and rear CV driveshafts
Front chromoly 44 axle shafts
Rear stock 44 shafts
« Reply #11 on: January 12, 2018, 04:48:41 PM »
I'm assuming the Genright tank is different than the JK one.
Offline Angrytj
  • Luciano
« Reply #12 on: January 12, 2018, 06:55:03 PM »
You’d be assuming correct
« Reply #13 on: January 12, 2018, 07:19:55 PM »
At least the temptation of buying it isn't there lol
Offline Angrytj
  • Luciano
« Reply #14 on: January 16, 2018, 06:33:37 PM »
Steering and front chromoly shafts
Online JeepinMaxx
« Reply #15 on: January 16, 2018, 07:12:42 PM »
What's the spline count on the shafts?
Offline Angrytj
  • Luciano
« Reply #16 on: January 17, 2018, 08:58:28 AM »
27 outer 30 inner
