Author Topic: It's Coming for YOU NEXT!!!  (Read 570 times)
Offline Miley Cyrus
Re: It's Coming for YOU NEXT!!!
« Reply #50 on: January 05, 2018, 09:42:06 PM »
well your truck cant do either one so.........
My truck could make my Washington the tj made 7/8 way up too lol, driveway is just an issue in icy snowy conditions with no 4wd driveway is bad enough nobody would ever want to plow it except me and I do it successfully as long as plows are running and vehicle has 4wd right now I have no plows soon I’ll have 2 plows again and then it prolly won’t snow though.
« Reply #51 on: January 05, 2018, 10:49:26 PM »
tomorrow I should probably scoop the snow I accidentally filled my Jeep with when I used the snow blower this evening
I did get the quad fired up to plow a path for our dog Presley to do her business...
Online A new level
« Reply #52 on: January 06, 2018, 06:40:56 AM »
Theres a check valve on the right side, on the tranny case. It may be stuck open. Mine stuck closed and kept blowing o rings. Theres also another check valve further down same side back by the rear tire. Follow the main steel fliud line that’s around 3/4” diameter. That could be why you’re dead stick.
Awesome! Thank you!!
