Author Topic: rear adams ds intall  (Read 203 times)
« on: January 06, 2018, 04:11:05 PM »
Hey guys,,quick question...came across a great deal on a adams 1310 rear ds....so why not....anyways 1/2 way through the install and not sure which yoke goes in t case,,,short or long one? maybe the spline count will tell me...lol
anyways thanks guys
Re: rear adams ds intall
« Reply #1 on: January 06, 2018, 07:20:56 PM »
Is it a double cardian shaft?  That end goes on the transfer case side
Offline Johny Pornstash
« Reply #2 on: January 06, 2018, 08:28:59 PM »
Always DC side to transfer case yoke. Short end with u joint on the diff.
« Reply #3 on: January 06, 2018, 10:53:01 PM »
No I understand about the DC...my question is which is the t case output yoke in the pic? The longer one? I think it’s the smaller shorter one that goes to the d44
« Reply #4 on: January 06, 2018, 10:59:30 PM »
You didn't post a pic - Double Cardian (sometimes in-correctly called a CV) is the hunk of metal with two u-joints next to each other
« Reply #5 on: January 07, 2018, 12:55:17 AM »
sorry
Pic posted now...the 2 yokes underneath driveshaft
Online A new level
« Reply #6 on: January 07, 2018, 05:56:54 AM »
I know Adams have install videos. Do they explain it there?
« Reply #7 on: January 07, 2018, 06:08:11 AM »
According to the pic you posted , the right side goes to the T-Case . I assume you dont have a slip yolk at that end. It looks as though both ends require a new yolk. Id see which one fits where and that will tell you for sure. Call them Dldos up and ask them where the paperwork is.   FjR68
« Reply #8 on: January 07, 2018, 08:51:41 AM »
perfect thanks.......yes the install vids are good but you can't see the yoke that well in them.....the front was easy......ill give a call....thanks for all the help though
« Reply #9 on: January 07, 2018, 08:59:43 AM »
If you don't have a double cardigan,  I'd put the splines on the transfer case side to get them higher and keep them out of the shallower mud and water.  Sometime clearance issues will determine which way you have to install it.
I don't know why but typically a CJ will come with the splines on the axle side in front and splines on the transfer case side in the rear.
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
« Reply #10 on: January 07, 2018, 10:18:07 AM »
 You guys aren't understanding the question...  he's not asking which end of the Drive Shaft goes where, he knows that.
 He's asking which of the two included yokes go where... tcase and axle sides...
 Markus, on a stock shaft the bolts go through the shaft and into the yoke on the axle side, and through the yoke and into the cv on the tcase side... (Though the pic you posted shows straps so that may bugger that idea up)...  take a look at the yokes and the shaft to see if you can identify the proper orientation that way.  If not you'll need to pull them and look at the spline count/depth and try to determine placement that way.  (They have to come out anyway...)
Profile for Team_Oscar
Quote from: Theo Maassen
« Reply #11 on: January 07, 2018, 05:15:40 PM »
All set ... d44 Side yoke diameter smaller than tcase side .. easy ... thanks again
« Reply #12 on: January 08, 2018, 06:11:20 AM »
In most cases , the CV would go to the T-Case.  In you case , its called an inverted shaft . Instead of the slip being up top , its at the Diff. Ive only seen this application on one factory shaft , and it didnt make sense then either.  Why would you have the big part driving the small part instead of the other way around. Id keep an eye on that slip joint, bet it dont last doing what we do.   FjR68
