Author Topic: throwout bearing  (Read 936 times)
throwout bearing
« on: January 22, 2018, 10:08:40 PM »
probably having to pull everything to replace ticking TO bearing..anyways JK has 48K on it...only want to pull it once ..think I should do clutch / pilot bearing all at the same time? or just TO bearing if everything else seems ok?
whats everyone else doing these days when this happens?
Re: throwout bearing
« Reply #1 on: January 22, 2018, 10:23:18 PM »
Always do clutch, pressure late and bearing as a set
« Reply #2 on: January 22, 2018, 10:36:53 PM »
If you are taking it that far apart - replace EVERYTHING you can while it's opened up!  Clutch, Pressure Plate, new Pressure Plate bolts, Throw out bearing, Pilot Bearing, etc...  You only want to open it up once  :wink:
« Reply #3 on: January 23, 2018, 05:32:42 AM »
Definitely do all especially seeing stock clutch sucks
« Reply #4 on: January 23, 2018, 06:32:31 AM »
Agree ...good advice
« Reply #5 on: January 23, 2018, 06:32:58 AM »
Start looking at kits I guess
« Reply #6 on: January 23, 2018, 08:10:16 AM »
I thought JKs were "throw away" Jeeps.  You know like TVs, they break, you replace em. :rotflmao:
« Reply #7 on: January 23, 2018, 09:06:48 AM »
I've never replaced pressure plate bolts. Is that really nessesary?
Online MassJK
« Reply #8 on: January 23, 2018, 10:31:30 AM »
Cheap insurance.   At a minimum hit them with a pitch gauge to make sure they are not streched
« Reply #9 on: January 23, 2018, 11:06:14 AM »
Technically speaking any bolt with a torque spec shouldn’t be reused
« Reply #10 on: January 23, 2018, 11:39:37 AM »
oil pan bolts have torque specs
« Reply #11 on: January 23, 2018, 11:43:22 AM »
Everything has a torque spec. :eek:
« Reply #12 on: January 23, 2018, 04:18:21 PM »
I have never changed a pressure plate bolt in my life.
I got 200K on my factory clutch in the beetle, with 50k on the ticker I'd only do the TO bearing.  The clutch is just breaking in.
« Reply #13 on: January 23, 2018, 04:31:55 PM »
sound like everyone likes luk?
« Reply #14 on: January 23, 2018, 05:43:55 PM »
spec/centerforce/etc?
« Reply #15 on: January 23, 2018, 06:33:12 PM »
I'll be doing a centerforce dual friction when the time comes
« Reply #16 on: January 23, 2018, 06:49:56 PM »
I use luk
« Reply #17 on: January 23, 2018, 07:22:07 PM »
lUK
« Reply #18 on: January 23, 2018, 08:17:18 PM »
Do I have to drop exhaust on the jk for this job? Hate the thought of going after those manifold nuts
« Reply #19 on: January 23, 2018, 08:44:57 PM »
Should be fine.  Spray and pray. :mrgreen:
Offline joe98tj
« Reply #20 on: January 23, 2018, 08:53:37 PM »
Now hes gonna be the first guy to blow all the pressure plate bolts
Mean, Green, Sticker Machine
Online MassJK
« Reply #21 on: January 23, 2018, 09:51:17 PM »
in the younger years and hot rod cars we would often see the head of the bolt off center.  we always did new bolts.    that was after lots of hole shots
« Reply #22 on: January 23, 2018, 10:18:49 PM »
Simply no reason not to replace the bolts while you have it apart with new grade 8 (or grade 10.9 or 12.9 if they are communist anti american hardware  :rotflmao: )
Online MassJK
« Reply #23 on: January 23, 2018, 10:22:42 PM »
until you know and understand bolt fatigue and failure a bolt is a bolt.
« Reply #24 on: January 24, 2018, 05:45:16 AM »
Something like this is similar to reusing head bolts
