Author Topic: throwout bearing  (Read 937 times)
Re: throwout bearing
« Reply #50 on: February 05, 2018, 07:30:50 PM »
thanks for all the help....ordered the luk oem (they don't make a pro gold for my year) and omnix tob/oem pivot ball(clip also)/PP bolts/and the 2 JK linkage plastic clips that sometimes break...all for 260.00....i can live with that price
Offline MasterDrazhar
  • Honorary Members
  • 'F' with me? I'll STAB YA!
« Reply #51 on: February 06, 2018, 07:56:45 AM »
 :applaud:
Profile for Team_Oscar
Quote from: Theo Maassen
« Reply #52 on: February 06, 2018, 08:32:02 AM »
YAY!!!
« Reply #53 on: February 06, 2018, 08:34:46 AM »
YAY!!!
now that the easy part is done :-) when pulling a jk transmission make sure to disconnect ALL the wiring that clips onto the top of the transmission. There are multiple wire loom sections  zip tied to the top.
make sure you have a long extension for the top bell housing bolts the floor is tight to the tranny
now is a good time to service the transfer case
« Reply #54 on: February 06, 2018, 05:04:23 PM »
home depot for zip ties ... lol....
thanks for talking me out of the center force ...now i have money left over...yay
« Reply #55 on: February 07, 2018, 09:30:26 AM »
Wouldn’t  you know it luk clutch for my jk all backordeed... no idea when they’ll be in.. maybe check with my dealer to see if he has any in stock
  • Honorary Members
« Reply #56 on: February 07, 2018, 11:20:55 AM »
 Try these guys:
http://www.carolinaclutch.com/inventory/2073-luk-stock-replacement-clutch-kits-01-046-jeep-stock-replacement-clutch-kit
Rockauto didn't have it, neither did CARiD, you can try Summit but they can be quite spendy...
« Reply #57 on: February 07, 2018, 09:10:49 PM »
I’ll check them tomorrow.. thanks
« Reply #58 on: February 11, 2018, 11:58:28 AM »
one more clutch question....i have the JK all torn down/all thats left is the housing to come off, just awaiting a couple more parts...anyways my question is once i angle the trans down a bit on the jack to get at the top bolts, do you guys put a jack under the front of engine to keep it in that position for easier reinstall?
« Reply #59 on: February 11, 2018, 02:41:56 PM »
Yes, just to support it.
« Reply #60 on: February 11, 2018, 06:37:39 PM »
Excellent thankyou
« Reply #61 on: February 16, 2018, 07:09:18 PM »
And it’s out... hardest part was gettIng shifter through floor .. that was a bitch...I wonder if it’s wise to unbolt shifter from tranny for reinstall
« Reply #62 on: February 16, 2018, 07:58:57 PM »
Yep remove it
« Reply #63 on: February 16, 2018, 08:08:48 PM »
definitely,,,does it just unbolt?
« Reply #64 on: February 16, 2018, 08:52:35 PM »
yep, put it in neutral, take the 4 bolts out and it lifts up. Goes back in the same way. Put a rag in the hole to keep crap out of it...
There's a plate on the floorboard you have to pull up and you drop the shifter through the floor to bolt it back up.
Offline Johny Pornstash
« Reply #65 on: February 16, 2018, 11:45:36 PM »
What year is your jeep? I'm probably due for a clutch, as it catches near the floor, but mine is 12 years old, and has 170,xxx+ish on it (wrong tire size for speedo gear for years).
I was thinking LUK, I'm sure it's more available for TJs since we're old and decrepit, like the YJs were when mine was new... :mad02: :mrgreen:
Gotta get my R&P fixed up first though...stupid metallic gear oil :eek:
« Reply #66 on: February 17, 2018, 07:49:06 AM »
2013 jk
Offline beaker
  • chillin and grillin
« Reply #67 on: February 17, 2018, 05:39:51 PM »
Even in the aerospace field.  Reusing bolts is common.  Hardware from home depot is not the same quality the oem's  use.  Unless its torque plus stretch,  reuse is fine.
« Reply #68 on: February 17, 2018, 11:29:56 PM »
yes ,,i actually replaced with new oem bolts.....actually just finished and everything back as it once was...only thing is i need a new slave.  when i went to put it back on the boot came off the end and it hyperextended into the hole the wrong way...needless to say removing it was not that easy....only one problem , i noticed when i got it out that the tiny plastic end was not there (it must have fallen in)...does this mean re-do or will it possibly fall out the holes on the bottom of the bell housing.....ughhhh
