Author Topic: Optional JL transfer case  (Read 113 times)
Offline JKDave
« on: January 23, 2018, 06:34:43 PM »
Has anyone noticed the optional Selec-Trac Full Time 4WD System available for $595 on Sahara model JL's? Here is the description from the Jeep website:
The new Selec-Trac® Full-Time Four-Wheel-Drive System includes a 2.72:1 low range. This two-speed, active full-time system includes a 4H AUTO mode that requires no driver input for any driving conditions. In 4H AUTO, 4WD is automatically engaged and disengaged as needed to maintain traction.
07 JKU w/ 4.5" Clayton SA rear & LA front; Front axle: Dynatrac ProRock 44 w/ 35 spline RCV's, ARB air locker, 5.13 gears, Synergy ball joints, Reid Racing knuckles, and TeraFlex Big Brake kit w/ slotted rotors; Rear axle: Dana 44 w/ 35 spline chromoly shafts, ARB air locker & 5.13 gears; Shrockworks rock sliders, Or-Fab rear corner guards w/ rails, GenRight steel tube fenders, Rugged Ridge XHD front bumper w/ stinger, ACE Engineering Pro Series rear bumper w/ tire carrier, Warn XD9000I, Tom Woods 1350's
Re: Optional JL transfer case
« Reply #1 on: January 23, 2018, 06:44:27 PM »
No 4 Low, no longer a Jeep. :rolleyes:
« Reply #2 on: January 23, 2018, 06:49:24 PM »
 :rolleyes:
Offline Red Rocker
« Reply #3 on: January 23, 2018, 07:00:05 PM »
If it's a two speed transfer case why wouldn't it have a 4 low.
My wifes Tahoe has something similar I guess.   2HI   4Auto   4HI   4Low
Just don't see a selection for Neutral.
When it's in 4Auto I think there are clutches in the case that engage when it see's a slip of the rear wheels and it engages the front shaft.
I know it takes a special transfer case fluid.
16 JKURR
Offline JKDave
« Reply #4 on: January 23, 2018, 07:04:38 PM »
It has 2H 4H Auto, 4H Part time, 4L, and N.
« Reply #5 on: January 23, 2018, 07:21:21 PM »
Think of it as the old np242 t cases with full time 4wd. I had one in my 92 XJ. It was great not having to shift out of 4wd on dry pavement.
« Reply #6 on: January 23, 2018, 07:38:23 PM »
Its probably AWD high and low but I'm a fan of putting things into gear manually. Apparently 1st gear in the 8 speed auto is lower than the 6 speed manual but I'd still take the 3 pedals
