Author Topic: Rear pinion  (Read 104 times)
Rear pinion
« on: January 27, 2018, 06:35:39 PM »
Rear Adams installed... hows the angle look? I think it’s 1-2 down..
Re: Rear pinion
« Reply #1 on: January 27, 2018, 06:36:36 PM »
Or more adjustment needed?
Re: Rear pinion
« Reply #2 on: January 27, 2018, 08:06:24 PM »
hard to tell from that picture
Generally you want the differential pinion pointing straight at the yoke on the T-Case (or a couple degrees down)
Re: Rear pinion
« Reply #3 on: January 27, 2018, 11:03:01 PM »
i think it might be 3 deg down but its set at RK spec for that lift....I can always extend the upper control arms 1 or 2 more turns if needed though..measure again tomorrow ...
